i would like to create a (nagvis) map with muliple hosts from different sites. In the map configuration menu → Obj. Defaults i can select one of the sites in “backend_id”. As i select one of the sites i can create the hosts from this single site on the map. I would like to create hosts from multiple sites on this single map though.
You can add multiple backend_id in NagVis, only 1 will be default.
When you add a host on the map it will be the default backend_id, but you can check and change backend_id if you please.
Not sure if or how to configure Checkmk so it sees the other sites.
First time for me working with nagvis maps. I didn’t know there was an option to change the backend id when creating an object on the map. The other sites are visible as backend_id’s in our configuration.
The latest essential NagVis information from Checkmk is on:
Additional information can be found at NagVis, but it may have new features / versions documented that is not yet in your installation of Checkmk: http://docs.nagvis.org/1.9/en_US/index.html
