Hi all,
may anyone help me get out of this?
CMK version:
2.2.0p8
OS version:
Debian bookworm 12.1
[agent] invalid load key, ‘{’.UNKN, [piggyback] Success (but no data found for this host), Missing monitoring data for all pluginsWARN,
Checkmk version 2.2.0p8
+ FETCHING DATA
Source: SourceInfo(hostname='hostname.domain.local', ipaddress='192.168.0.1', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f1d564c42d0]
Read from cache: AgentFileCache(hostname.domain.local, path_template=/omd/sites/kohly/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 10 sec, allowed is 0 sec)
Connecting via TCP to 192.168.0.1:6556 (5.0s timeout)
Reading data from agent
Closing TCP connection to 192.168.0.1:6556
Write data to cache file /omd/sites/kohly/tmp/check_mk/cache/hostname.domain.local
Trying to acquire lock on /omd/sites/kohly/tmp/check_mk/cache/hostname.domain.local
Got lock on /omd/sites/kohly/tmp/check_mk/cache/hostname.domain.local
Releasing lock on /omd/sites/kohly/tmp/check_mk/cache/hostname.domain.local
Released lock on /omd/sites/kohly/tmp/check_mk/cache/hostname.domain.local
[cpu_tracking] Stop [7f1d564c42d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=4.900000002235174))]
Source: SourceInfo(hostname='hostname.domain.local', ipaddress='192.168.0.1', ident='special_proxmox_ve', fetcher_type=<FetcherType.SPECIAL_AGENT: 6>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f1d571facd0]
Read from cache: AgentFileCache(hostname.domain.local, path_template=/omd/sites/kohly/tmp/check_mk/data_source_cache/special_proxmox_ve/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 13 sec, allowed is 0 sec)
Calling: /omd/sites/kohly/share/check_mk/agents/special/agent_proxmox_ve -u checkmk@pve -p UMRMrwlCK0Y --no-cert-check hostname.domain.local
Write data to cache file /omd/sites/kohly/tmp/check_mk/data_source_cache/special_proxmox_ve/hostname.domain.local
Trying to acquire lock on /omd/sites/kohly/tmp/check_mk/data_source_cache/special_proxmox_ve/hostname.domain.local
Got lock on /omd/sites/kohly/tmp/check_mk/data_source_cache/special_proxmox_ve/hostname.domain.local
Releasing lock on /omd/sites/kohly/tmp/check_mk/data_source_cache/special_proxmox_ve/hostname.domain.local
Released lock on /omd/sites/kohly/tmp/check_mk/data_source_cache/special_proxmox_ve/hostname.domain.local
[cpu_tracking] Stop [7f1d571facd0 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=0.77, children_system=0.14, elapsed=1.300000000745058))]
Source: SourceInfo(hostname='hostname.domain.local', ipaddress='192.168.0.1', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f1d5712b050]
Read from cache: NoCache(hostname.domain.local, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'hostname.domain.local'. Skip processing.
No piggyback files for '192.168.0.1'. Skip processing.
[cpu_tracking] Stop [7f1d5712b050 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<zfsget:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<zfsget>>> / Transition HostSectionParser -> HostSectionParser
<<<nfsmounts_v2:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<lnx_bonding:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<ovs_bonding:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<zpool_status>>> / Transition HostSectionParser -> HostSectionParser
<<<zpool>>> / Transition HostSectionParser -> HostSectionParser
<<<fileinfo:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<lnx_thermal:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<pvecm_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<pvecm_nodes>>> / Transition HostSectionParser -> HostSectionParser
<<<chrony:cached(1692793755,120)>>> / Transition HostSectionParser -> HostSectionParser
<<<dmi_sysinfo>>> / Transition HostSectionParser -> HostSectionParser
<<<sshd_config:cached(1692793511,300)>>> / Transition HostSectionParser -> HostSectionParser
<<<apt:cached(1692793395,3600):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<apcaccess:cached(1692793762,60):sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<cpufreq:cached(1692793756,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<mrpe:cached(1692793756,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<lvm_vgs:cached(1692793756,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<lvm_lvs:cached(1692793756,60):sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<filehandler:cached(1692793756,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<iptables:cached(1692793756,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<logins:cached(1692793756,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<logwatch:cached(1692793757,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<nfsiostat:cached(1692793757,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<netstat:cached(1692793757,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<smart:cached(1692793757,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<systemd:cached(1692793757,60)>>> / Transition HostSectionParser -> HostSectionParser
############## Piggyback information removed ##############
Received piggyback data for 13 hosts
[cpu_tracking] Start [7f1d56172d90]
value store: synchronizing
Trying to acquire lock on /omd/sites/kohly/tmp/check_mk/counters/hostname.domain.local
Got lock on /omd/sites/kohly/tmp/check_mk/counters/hostname.domain.local
Releasing lock on /omd/sites/kohly/tmp/check_mk/counters/hostname.domain.local
Released lock on /omd/sites/kohly/tmp/check_mk/counters/hostname.domain.local
APC apcupsd.conf Status PEND Check plugin received no monitoring data
APT Updates PEND Check plugin received no monitoring data
CPU load PEND Check plugin received no monitoring data
CPU utilization PEND Check plugin received no monitoring data
Check_MK Agent PEND Check plugin received no monitoring data
DMI Sysinfo PEND Check plugin received no monitoring data
Disk IO LVM pve-root PEND Check plugin received no monitoring data
Disk IO LVM pve-swap PEND Check plugin received no monitoring data
Disk IO SUMMARY PEND Check plugin received no monitoring data
Disk IO sda PEND Check plugin received no monitoring data
File group kernel config PEND Check plugin received no monitoring data
File group kernel image PEND Check plugin received no monitoring data
File group kernel initrd PEND Check plugin received no monitoring data
Filecount_/boot PEND Check plugin received no monitoring data
Filecount_/tmp PEND Check plugin received no monitoring data
Filecount_/var/cache/apt/archives PEND Check plugin received no monitoring data
Filecount_/var/log PEND Check plugin received no monitoring data
Filehandler PEND Check plugin received no monitoring data
Interface eth0 PEND Check plugin received no monitoring data
Interface eth1 PEND Check plugin received no monitoring data
Interface lan PEND Check plugin received no monitoring data
Interface lo PEND Check plugin received no monitoring data
Interface ovs-system PEND Check plugin received no monitoring data
Interface vmbr0 PEND Check plugin received no monitoring data
Iptables PEND Check plugin received no monitoring data
Kernel Performance PEND Check plugin received no monitoring data
LOG /var/log/apcupsd.events PEND Check plugin received no monitoring data
LOG /var/log/auth.log PEND Check plugin received no monitoring data
LOG /var/log/kern.log PEND Check plugin received no monitoring data
LOG /var/log/messages PEND Check plugin received no monitoring data
LOG /var/log/syslog PEND Check plugin received no monitoring data
LVM VG pve PEND Check plugin received no monitoring data
Logins PEND Check plugin received no monitoring data
Memory PEND Check plugin received no monitoring data
Mount options of / PEND Check plugin received no monitoring data
Mount options of /boot PEND Check plugin received no monitoring data
Mount options of /etc/pve PEND Check plugin received no monitoring data
NTP Time PEND Check plugin received no monitoring data
Number of threads PEND Check plugin received no monitoring data
Postfix Queue PEND Check plugin received no monitoring data
Postfix status PEND Check plugin received no monitoring data
Proxmox VE Memory Usage Usage: 76.49% - 11.9 GiB of 15.5 GiB
Proxmox VE Node Info Status: online, Subscription: invalid, Version: 8.0.4, Hosted VMs: 0x LXC, 11x Qemu
Resolve_gw01.kohly.de PEND Check plugin received no monitoring data
SMART Samsung_SSD_840_EVO_500GB_mSATA_S1KMNSAF501737Z Stats PEND Check plugin received no monitoring data
SSH daemon configuration PEND Check plugin received no monitoring data
System_info_cpu PEND Check plugin received no monitoring data
System_info_debian_version PEND Check plugin received no monitoring data
System_info_hardware PEND Check plugin received no monitoring data
System_info_os-release PEND Check plugin received no monitoring data
System_info_uname-a PEND Check plugin received no monitoring data
System_info_uname-r PEND Check plugin received no monitoring data
System_info_uname-v PEND Check plugin received no monitoring data
Systemd Service Summary PEND Check plugin received no monitoring data
Systemd Socket Summary PEND Check plugin received no monitoring data
TCP Connections PEND Check plugin received no monitoring data
Temperature Zone 0 PEND Check plugin received no monitoring data
Temperature Zone 1 PEND Check plugin received no monitoring data
Temperature Zone 2 PEND Check plugin received no monitoring data
Uptime Up since Aug 18 2023 14:46:51, Uptime: 4 days 23 hours
fs_/ PEND Check plugin received no monitoring data
fs_/boot PEND Check plugin received no monitoring data
fs_/etc/pve PEND Check plugin received no monitoring data
reboot PEND Check plugin received no monitoring data
sshsessions PEND Check plugin received no monitoring data
[cpu_tracking] Stop [7f1d56172d90 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
**[agent] invalid load key, '{'.(?)**, [special_proxmox_ve] Success, [piggyback] Success (but no data found for this host), Missing monitoring data for plugins: apcaccess, apt, checkmk_agent, chrony, cpu_loads, cpu_threads, df, diskstat, dmi_sysinfo, filehandler, fileinfo_groups, iptables, kernel_performance, kernel_util, lnx_if, lnx_thermal, local, logins, logwatch, lvm_vgs, mem_linux, mounts, mrpe, nfsiostat, nfsmounts, postfix_mailq, postfix_mailq_status, smart_stats, sshd_config, systemd_units_services_summary, systemd_units_sockets_summary, tcp_conn_stats(!), execution time 6.2 sec | execution_time=6.210 user_time=0.020 system_time=0.010 children_user_time=0.770 children_system_time=0.140 cmk_time_agent=4.890 cmk_time_ds=0.380
