Hello fellow CheckMK users,
I’m fairly new to CheckMK and Python, but I am trying to write some scripts that can monitor Quantum’s RAS tickets or retrieve other information from the tape library via SNMP.
After doing some research, I am still unable to identify the errors causing the script to fail in creating the services. That’s why I’m asking for your guidance to point me in the right direction.
This script should create a new service for each existing RAS ticket and display the contents of the ticket.
from .agent_based_api.v1 import (
register,
startswith,
Result,
Service,
SNMPTree,
State,
def discover_quantum(section):
for eventTicketID, eventTicketDateTime, eventTicketName, eventTicketDescription, eventTicketSeverity in section:
yield Service()
def checkTicketContent(section): #Ticket content auslesen und angeben
if eventTicketSeverity == 1:
yield Result(state = State.CRIT, summary=f"{eventTicketID} / {eventTicketDateTime} / {eventTicketName} / {eventTicketDescription} / {eventTicketSeverity}") #Severity critical
elif eventTicketSeverity == 3 or eventTicketSeverity == 0 or eventTicketSeverity == 2 or eventTicketSeverity == 4:
yield Result(state = State.WARN, summary=f"{eventTicketID} / {eventTicketDateTime} / {eventTicketName} / {eventTicketDescription} / {eventTicketSeverity}") #Severity unknown/degraded/attention
else:
yield Result(state = State.OK, summary=f"{eventTicketID} / {eventTicketDateTime} / {eventTicketName} / {eventTicketDescription} / {eventTicketSeverity}") #Severity informational
return
register.snmp_section(
name = "QuantumRAS",
detect = all_of(
startswith(".1.3.6.1.2.1.1.1.0", "Linux library 4.9.243") #SysDesc OID, "Linux library 4.9.243" ist die Beschreibung der Quantum Scalar i3
fetch=[
SNMPTree(
base=".1.3.6.1.4.1.3697.1.10.15.5.50.10.2.1",
oids = [
"2", #TicketID
"3", #DateTime
"5", #Name
"6", #Description
"7" #Severity
register.check_plugin(
name="QuantumRAS",
sections=["Quantum_RAS_Ticket"],
service_name="RAS Ticket",
discovery_function=discover_quantum,
check_function=checkTicketContent
I understand that the code is not optimal and there are likely many mistakes, but please keep in mind that I just started learning Python yesterday.
I am grateful for any help that i can receive.
