CMK version: 2.3.0p10.cre
OS version: Debian GNU/Linux 12 (bookworm)
NetApp Version: NetApp Release 9.13.1P9
Error message: [special_netapp_ontap]: KeyError: ‘qtree’
Output from Debug of special_netapp_ontap
Executed Command:
/omd/sites/<sitename>/share/check_mk/agents/special/agent_netapp_ontap --pwstore=<pwstore> --hostname <hostname> --username monitoring --password '***************' --no-cert-check --debug
<<<netapp_ontap_qtree_quota:sep(0)>>>
File "/omd/sites/<sitename>/share/check_mk/agents/special/agent_netapp_ontap", line 11, in <module>
sys.exit(main())
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/agent_netapp_ontap.py", line 880, in main
return special_agent_main(parse_arguments, agent_netapp_main)
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/v0_unstable/agent_common.py", line 173, in special_agent_main
return _special_agent_main_core(parse_arguments, main_fn, argv or sys.argv[1:])
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/v0_unstable/agent_common.py", line 149, in _special_agent_main_core
return main_fn(args)
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/agent_netapp_ontap.py", line 872, in agent_netapp_main
write_sections(connection, logger, args)
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/agent_netapp_ontap.py", line 824, in write_sections
write_section("qtree_quota", fetch_qtree_quota(connection), logger)
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/agent_netapp_ontap.py", line 27, in write_section
for element in generator:
File "/omd/sites/<sitename>/lib/python3/cmk/special_agents/agent_netapp_ontap.py", line 735, in fetch_qtree_quota
name=element_data["qtree"]["name"],
KeyError: 'qtree'
I can see much data on the output from this command before the error, so it seems it´s something about qtree information from the rest api.
