2.1.0p16:
CentOS 8.3:
CRITICAL - ...: rta 596.622ms, lost 0%
No one will be able to reply unless you explain a little more what the issue is
rta over 500ms triggers a CRIT with default parameters.
You can change the threshold via the rule PING and host check parameters.
Otherwise we need more information, like gstolz said.
Cheers Jeronimo
Thanks, I have fixed this issue.
