CheckMK 2.0.0p29
Ubuntu 20.04 (checkmk server is hosted on this)
OpenSUSE 15 - (server that has our websites and Nginx)
Good morning CheckMK community,
I was following the CheckMK guide → Nginx - Checkmk Knowledge Base - Checkmk Knowledge Base regarding monitoring our NGINX status for 4 different websites we have, but noticed some differences between the setup guide and our environment (folder locations of config files).
First, I checked and confirmed the server process is configured with the stub status module by running the following command:
'nginx -V 2>&1 | grep -o with-http_stub_status_module ’
The second part is where the differences are noticeable, I tried checking to find the /etc/nginx/sites-enabled/default folder but do not see this listed within the directory:
Just to note, I do see websites populated in the “vhosts.d” folder that have the .conf files for each of the sites, but just wanted to see if this is the location that I would write the added entry to.
Any help is always appreciated!
-Justin
