No graphs after upgrade from CRE to CEE
CMK version: 1.6.0p30 CEE
OS version: Linux 8.x
Error message: no graphs are showing after upgrade from 1.6.0p30 CRE to 1.6.0p30 CEE
If I select a graph, e.g. Filesystem usage I see no graphs and the attached error.
I’ve copied the old graphs from nagios:
cp var/nagios/nagios.log var/check_mk/core/archive/
cp var/nagios/archive/* var/check_mk/core/archive/
I did check the RRD data convert (but data was “uptodate”:
cmk -v --convert-rrds
cmk -v --convert-rrds --delete-rrds
I’ve renamed the host check RRD data for Smart Ping:
/var/pnp4nagios/perfdata/ HOST* → PING*
Did I miss something else?
