Not able to receive alerts to CheckMK from Grafana
Hi All,
Need your suggestions/support on the below scenario.
We have a environment were we need to send alerts from Grafana and receive them in Check_MK under Event console.
We have tried to use the option of Webhook in Grafana to send the alert notification and could also see the entries in the Log file.
Created a rule in Event Console Module to receive all the data, so that we can fine tune the conditions based on the data received. But we don’t see any events received under Event console.
Could you please suggest us here if we are missing anything.
Thanks.
This here
could help to translate the webhook to an syslog message that can be received by the event console.
Thanks @andreas-doehler for the response. Can’t we directly forward those alert to Check_MK Event Console.
As we don’t have syslog server we need to look for this option.
Or do we have any other option ?
The Event Console is a syslog server/receiver.
Thanks @andreas-doehler.
We have tried using .exe file which was available in the GitHub.
But it didn’t work. (We didn’t have for Linux.)
Below is the flow we did (As we didn’t had plugin for Linux, took Windows Jump box which has communication with both Grafana and Check_MK).
Grafana Server (Used Windows Jump Box IP in the Webhook) —> Windows Jump (Gave CMK Server IP in the Command) —> Check_MK (Event Console).
Still no luck. not able to see events in CMK Event Console.
We could see the logs showing as data sent.
Not sure, what is missing.
Thanks.
Thanks @andreas-doehler We are able to receive the alerts from Grafana to CheckMK Event Console.
