CMK version: 2.0.0p23 (CRE) and previus versions too
OS version: ubuntu 20.01 and in centos 7 too
OMD[eldofi]:~$ cmk --debug -vvn 10.14.30.201
Checkmk version 2.0.0p23
Trying to acquire lock on /omd/sites/eldofi/var/check_mk/license_usage/next_run
Got lock on /omd/sites/eldofi/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/eldofi/var/check_mk/license_usage/history.json
Got lock on /omd/sites/eldofi/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/eldofi/var/check_mk/license_usage/history.json
Released lock on /omd/sites/eldofi/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/eldofi/var/check_mk/license_usage/next_run
Released lock on /omd/sites/eldofi/var/check_mk/license_usage/next_run
Updating IPv4 DNS cache for 10.14.30.201: 10.14.30.201
Trying to acquire lock on /omd/sites/eldofi/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/eldofi/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/eldofi/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/eldofi/var/check_mk/ipaddresses.cache
+ FETCHING DATA
[cpu_tracking] Start [7fa967474640]
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/eldofi/tmp/check_mk/data_source_cache/piggyback/10.14.30.201'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
No piggyback files for '10.14.30.201'. Skip processing.
[cpu_tracking] Stop [7fa967474640 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7fa967474a60]
+ PARSE FETCHER RESULTS
No persisted sections loaded
-> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/eldofi/tmp/check_mk/counters/10.14.30.201
Got lock on /omd/sites/eldofi/tmp/check_mk/counters/10.14.30.201
Releasing lock on /omd/sites/eldofi/tmp/check_mk/counters/10.14.30.201
Released lock on /omd/sites/eldofi/tmp/check_mk/counters/10.14.30.201
[cpu_tracking] Stop [7fa967474a60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
OMD[eldofi]:~$
We have severals OLT huawei. We create new rule for this hosts in " [Network interface and switch port discovery] add or only 250-gpon or all types. but never discover our interfaces :(.
In “Inventory of host” this interfaces are inventarice, whith his estatus etc:
it is an issue? How can we fix it?
regards
