cmk Version 2.10p27
the issue is that i get notifications only for ONE of these services in Screenshot.
Both Services are configured identical… (i cant see any diffrence or dont know where to look).
Both Services are labeld notify:kksupport Labels. I use these labels as a condition for sending pushovernotifications.
the "GBPostal_API_CHECK_2" send notifications and I can also find it in the notifciation Listview when the Services switches to CRIT and also when it switches back to “OK” but the other Service
“GBPostal_API_CHECK” is not in the notification list what means that the Notification can not be triggered as the Event is missing.
Both Services go to CRIT but only one of them generates and Event that will afterwards fire a notification.
Who has Ideas to troubleshoot and find the Issue?
Only One of the Services is in the NotificationListview:
Thanks a lot in advance for your help/ideas
