That is because the environment variable NOTIFY_WHAT is not set when you call the script manually like you did. The same is true for all the other NOTIFY_* variables in your script.
But if the script gets called by checkmk to issue a notification, these variables are set to sensible values. For example, NOTIFY_WHAT will be set to either HOST or SERVICE depending on what caused the notification.
Difficult to diagnose without seeing your notification rule test. Did you select something in the CONTACT SELECTION pane? Maybe checkmk simply doesn’t know whom to notify.
Yes, I know exactly what you mean and had the same thoughts before. I believe checkmk “thinks” if nobody is on the contact list, then nobody needs to be notified. Maybe this is kind of legacy code as the first notification method that jumps to mind is email. I’m pretty sure checkmk started with that. Meanwhile we have other notiication methods which by themselves do not require a dedicated recipient (like your POST request) but checkmk apparently requires one.
Try checking the Notify all contacts of the notified host or service. box and make sure at least one user is a contact for the host in question. I created a technical notification user for that purpose and made him a contact for everything. He doesn’t even have a password set so I assume he cannot login but because he’s a contact, he gets notifications.
You are welcome. Another possibility is to create such a technical notification-user but don’t make him contact for anything. Create him as a regular user (no admin rights required), and disable his login. Then, in the notification rule, select just this particular user as a contact:
This approach is perhaps easier to understand. At least I thought so. Also, this avoids the following question: “How many POST requests are sent if multiple users are in the contact list for a problem?”
