Notification got 1 hour delay due to host flapping alert
CMK version: cmk --version This is Check_MK version 2.4.0p21 CRE
OS version: OMD - Open Monitoring Distribution Version 2.4.0p21.cre
Recently, we enabled flapping detection for both hosts and services. However, we observed an issue where a monitored device remained in a DOWN state for approximately one hour, but no notification was generated during that period.
Need help for below pointer:
  • Flapping should continue to be detected and monitored.
  • A host DOWN notification should be triggered within 5 minutes of the outage.
  • Notification delivery should not be delayed due to flapping configuration.
Hello @burhandm ,
This is normal behavior when flapping detected. in your snapshot, host down alert came before “Host Flapping Stopped”. Please go through section 4.5 in Notification basics , it clearly mentioned “As long as an object is flapping, successive state changes trigger no further notifications.
Regards,
DD
As @dineshinspace already wrote you can only have one of the two not booth.
You can disable flap detection or you can have the system like it is now.
Maybe the alerting side can help here as well. For example, SIGNL4 can be configured to wait until a problem persists for a certain period before sending an alert.
You can also define thresholds such as: one flap within 10 minutes is acceptable, but if the same problem occurs twice within 10 minutes, an alert is triggered.
