I thought that would be quite easy to configure, but it seems not to be so.
I’d like to have a notification which is sent …
- … with one hour delay (no problem with that)
- … only when in notification period (no problem with that)
- … when the notification periods begins - the notification should be sent, when the state is still critical (HOW TO DO THAT?)
- … repeatedly every 2 days (no problem with that)
I assumed the notification will automatically be sent, when the notification timeperiod starts.
A possibility I do not like is disabling the check completely via “check period” rule. I’d like to have the performance data 24x7.
At the moment I activated the notifications 24x7.
Is there a way to have those states notified as soon as the notification time periods starts?
Regards,
Jack
