I made an up to date version of my extended Nutanix monitoring.
It brings Nutanix on the “same” level as the ESX monitoring, i hope so
This version should be the last stand alone extension to this included agent and checks.
I migrated all legacy plugins to the new API and asked for how-to submit the whole bunch of data to the CMK github. A PR with around 50-60 files is not liked by the Munich team i think.
The 2.1 package should also work with 2.0 - if someone can test it, it would be helpful.
The packages marked with 2.2 and complete please ignore.
Update - i got information that the 2.1 package is not completely compatible with 2.0
I will have a look at this problem the next days.
The problem are with the check parameters as far as i know.
Thanks Andreas for these great checks. They’re much more helpful than that what comes with checkmk itself. I hope tribe29 will include this in future checkmk releases.
@andreas-doehler I get:
$ cmk -D foo.bar.com
Failed to auto-migrate legacy plugin to check plugin: prism_alerts
Please refer to Werk 10601 for more information.
Failed to auto-migrate legacy plugin to check plugin: prism_containers
Failed to auto-migrate legacy plugin to check plugin: prism_info
Failed to auto-migrate legacy plugin to check plugin: prism_storage_pools
Do we need to remove the existing cmk nutanix integration before?
Program: /omd/sites/xxx/share/check_mk/agents/special/agent_prism '--server' 'x.x.x.x' '--port' '9440' '--username' 'foo' '--password' 'bar'
Servername, Port, User and Password is ok, but I’m wondering why it seems to use the builtin agent_prism?
Ok that is strange - what package of the prism agent from my github do you have installed?
If it is CMK 2.1 than it can be ok
The shown path is only a wrapper and it calls then the right function from ~/local/lib/check_mk/…
Hi Andreas
i installed your package for 2.0 (v 3.3) on a 2.0.0p27 and have it run against a Nutanix prism 5.20.3. (i know its not the most recent one but the only one i can test it now).
Where the builtin checks work (1st screenshot), the checks of your MKP throw an exception (2nd screenshot):
This is what the crash report looks like of one of the container checks:
