Nutanix - PRISM Alerts
Hello Al,
I’m using Check_MK Raw 2.4 0p5 and have Nutanix devices configured. There’s an alert called PRISM Alerts, and I want to know if there’s a way to filter the information that Check_MK collects. I only need it to report errors and status warnings, not the informational alerts.
I need to filter only the warning and critical messages.
Is this possible?
Thanks in advance.
Regards,
Vix.
The agent does only transmit events that are in the state not “acknowledged” and not “resolved”.
There is no severity selection or any other filtering in the agent at the moment.
The check itself only alerts if there is a warning or critical message inside.
If only informational messages are existing the check will stay OK. Only showing the informational messages.
It would be awesome if it was possible to filter based on severity. I think the prism alerts are quite chatty.
@David-L for your info
This function is already present in the latest build of the Nutanix v4 mkp.
I had only no time to update the post here :smiley:
The function i included is from sebastian.haeger@sva.de and allows the special agent to produce the log output as normal logwatch output.
This can be configured there inside the special agent config.
As every logwatch output you can filter and rewrite the criticality and so on.
Also i had no time to test it on a live system :wink:
Link to post Nutanix Prism Central v4
Hello!
Thank you!
