OIDC and SAML broken on Debian 13 Trixie (2.4.0p22) — conflicting OpenSSL dependencies
Hello guys, here are my troubles :
**Component:** Linux distribution packaging / Debian 13 Trixie
**Checkmk version:** 2.4.0p22 RAW (check-mk-raw-2.4.0p22_0.trixie_amd64.deb)
**OS:** Debian 13 Trixie
**Edition:** Checkmk Raw (CRE)
Summary
Enabling OpenID Connect (and similarly SAML) on Checkmk 2.4.0p22 installed on Debian 13 Trixie results in a fatal library conflict that makes authentication completely non-functional. The root cause is a double OpenSSL dependency conflict in the Trixie package that cannot be worked around from the outside.
Symptoms
When OpenID Connect is enabled, one of the following errors appears in ~/var/log/apache/error_log:
**Error 1** (without any LD_PRELOAD workaround):
ImportError: libssl.so.3: version OPENSSL_3.2.0 not found
(required by /usr/lib/x86_64-linux-gnu/libcurl.so.4)
**Error 2** (when attempting to force system libcurl via LD_PRELOAD):
ImportError: …/cryptography/hazmat/bindings/_rust.abi3.so:
undefined symbol: EVP_idea_ecb, version OPENSSL_3.0.0
Root Cause Analysis
The Trixie package ships its own bundled libssl.so.3 / libcrypto.so.3 (OpenSSL **3.0.19**), and sets LD_LIBRARY_PATH to prioritize them. However, two mutually exclusive conflicts arise:
**Conflict 1 — system libcurl vs. bundled libssl:**
  • libcurl4t64 on Trixie (v8.14.1-2) was compiled against OpenSSL 3.2+ and requires the symbol OPENSSL_3.2.0
  • Checkmk’s bundled libssl.so.3 (3.0.19) only exposes OPENSSL_3.0.0 and OPENSSL_3.0.3
  • When LD_LIBRARY_PATH is active, libcurl.so.4 picks up Checkmk’s bundled libssl.so.3 → crash
**Conflict 2 — bundled _rust.abi3.so vs. system libssl:**
  • Checkmk’s bundled cryptography/hazmat/bindings/_rust.abi3.so requires the symbol EVP_idea_ecb (an IDEA legacy cipher)
  • This symbol has been removed from OpenSSL 3.x on Trixie and is not exported by libcrypto.so.3 system, nor by the openssl-provider-legacy package
  • When LD_LIBRARY_PATH is bypassed, _rust.abi3.so picks up the system libssl.so.3 → crash
**These two conflicts are mutually exclusive:** no single libssl.so.3 available on Trixie satisfies both requirements simultaneously.
Verification commands run against the package:
Bundled libssl version
strings /omd/sites//lib/libcrypto.so.3 | grep -E “^3\.”
→ 3.0.19
Symbols exposed by bundled libssl: only OPENSSL_3.0.0 and OPENSSL_3.0.3
Symbols exposed by system libssl: OPENSSL_3.0.0, 3.2.0, 3.3.0, 3.4.0, 3.5.0
EVP_idea_ecb absent from system libcrypto:
nm -D /usr/lib/x86_64-linux-gnu/libcrypto.so.3 | grep EVP_idea_ecb
→ (no output)
EVP_idea_ecb also absent from openssl-provider-legacy:
nm -D $(find /usr/lib -name “legacy.so”) | grep EVP_idea_ecb
→ (no output)
Expected Fix
my suggestions:
  1. **Bundle libcurl** linked against Checkmk’s own OpenSSL 3.0.19, instead of relying on the system libcurl4t64 which requires OpenSSL 3.2+
  2. **Recompile the cryptography Python package** (_rust.abi3.so) without dependency on legacy OpenSSL symbols such as EVP_idea_ecb, which are unavailable on modern distributions
This issue also affects SAML (same code path, same library conflict), as reported by other users on the forum.
Additional Notes
This is related to Werk #18937 (OpenSSL compatibility wrappers), but the wrapper mechanism does not cover the library conflicts triggered by the OIDC/SAML code path.
This bug was identified by inspecting the contents of check-mk-raw-2.4.0p22_0.trixie_amd64.deb directly.
Best regards,
Can you provide the steps to reproduce this issue?
