Omd backup issue
Checkmk version 2.3.0p28:
**Ubuntu 24.04.2 LTS **
omd backup hangs / sudo omd backup prompts for password
I am attempting to back up using OMD which is something i have done in the past before upgrading.
I run sudo su - OMDNAME then attempt to run omd backup OMDNAME /path/to/backup.tz
This appears to never complete.
If i run sudo omd backup OMDNAME /path/to/backup.tz i am prompted for a password which i do not know (i have tried all the passwords i configured during installation.
Is there anything i can check? do i just need to wait for longer?
i would like to upgrade to 2.4 but not until i have a backup!
thansk in advance.
Have you tried running the backup from the UI? Backups - Backing up and restoring data
For omd backup the site name is only used from root’s CLI without sudo Site administration with omd
As the site user it should be omd backup /absolute/path/mysite.tar.gz
As root it should be omd backup mysite /absolute/path/mysite.tar.gz
