CMK version:
2.1.0p6 RAW
OS version:
OpenBSD7.1
After the upgrade to 2.1 from 2.0(both the agent and monitor server). He can’t monitor the network interface correctly:
Checkmk version 2.1.0p6
Trying to acquire lock on /omd/sites/REDACTED/var/check_mk/license_usage/next_run
Got lock on /omd/sites/REDACTED/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/REDACTED/var/check_mk/license_usage/history.json
Got lock on /omd/sites/REDACTED/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/REDACTED/var/check_mk/license_usage/history.json
Released lock on /omd/sites/REDACTED/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/REDACTED/var/check_mk/license_usage/next_run
Released lock on /omd/sites/REDACTED/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f230bc17e80]
[PiggybackFetcher] Fetch with cache settings: NoCache(hostname, base_path=/omd/sites/REDACTED/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'hostname'. Skip processing.
Piggyback file '/omd/sites/REDACTED/tmp/check_mk/piggyback/ntp.REDACTED.lan/vcsa.REDACTED.nl': Successfully processed from source 'vcsa.REDACTED.nl'
[cpu_tracking] Stop [7f230bc17e80 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<esx_vsphere_vm:cached(1658154148,90)>>> / Transition NOOPParser -> HostSectionParser
No persisted sections
-> Add sections: ['esx_vsphere_vm', 'labels']
Received no piggyback data
[cpu_tracking] Start [7f230bbeb8b0]
value store: synchronizing
Trying to acquire lock on /omd/sites/REDACTED/tmp/check_mk/counters/hostname
Got lock on /omd/sites/REDACTED/tmp/check_mk/counters/hostname
Releasing lock on /omd/sites/REDACTED/tmp/check_mk/counters/hostname
Released lock on /omd/sites/REDACTED/tmp/check_mk/counters/hostname
[cpu_tracking] Stop [7f230bbeb8b0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[piggyback] Successfully processed from source 'vcsa.REDACTED.nl', execution time 0.0 sec | execution_time=0.010 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.00
** RAW output of the check_mk_agent **
<<<check_mk>>>
Version: 2.1.0p6
AgentOS: openbsd
Hostname: ntp.REDACTED.lan
AgentDirectory: /etc
DataDirectory:
SpoolDirectory:
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
<<<df>>>
/dev/sd0a ffs 1198894 118560 1020390 10% /
/dev/sd0e ffs 2061054 722 1957280 0% /home
/dev/sd0d ffs 3093230 1911310 1027260 65% /usr
<<<ps>>>
(root,636,100,0.0) /sbin/init
(root,984,24,0.0) /sbin/slaacd
(_slaacd,984,24,0.0) slaacd: engine (slaacd)
(_slaacd,1000,24,0.0) slaacd: frontend (slaacd)
(root,1020,24,0.0) /sbin/dhcpleased
(_dhcp,1020,24,0.0) dhcpleased: engine (dhcpleased)
(_dhcp,1040,24,0.0) dhcpleased: frontend (dhcpleased)
(root,228,8,0.0) /sbin/resolvd
(root,740,768,0.0) syslogd: [priv] (syslogd)
(_syslogd,1236,1320,0.0) /usr/sbin/syslogd
(root,980,216,0.0) pflogd: [priv] (pflogd)
(_pflogd,1020,288,0.0) pflogd: [running] -s 160 -i pflog0 -f /var/log/pflog
(_ntp,1364,1680,0.0) ntpd: ntp engine (ntpd)
(_ntp,940,1164,0.0) ntpd: dns engine (ntpd)
(root,1196,1596,0.0) /usr/sbin/ntpd
(root,1136,1292,0.0) sshd: /usr/sbin/sshd [listener] 0 of 10-100 startups
(root,1728,1536,0.0) /usr/sbin/smtpd
(_smtpd,1464,24,0.0) smtpd: crypto (smtpd)
(_smtpd,1728,1524,0.0) smtpd: control (smtpd)
(_smtpd,1548,1876,0.0) smtpd: lookup (smtpd)
(_smtpd,2104,2096,0.0) smtpd: dispatcher (smtpd)
(_smtpq,1676,1768,0.0) smtpd: queue (smtpd)
(_smtpd,1460,1560,0.0) smtpd: scheduler (smtpd)
(root,560,808,0.0) /usr/sbin/inetd
(_sndio,2668,24,0.0) /usr/bin/sndiod
(_sndiop,2660,24,0.0) sndiod: helper (sndiod)
(root,888,1240,0.0) /usr/sbin/cron
(root,1196,4032,0.0) sshd: admin [priv] (sshd)
(admin,1400,3348,0.0) sshd: admin@ttyp0 (sshd)
(admin,896,908,0.0) -ksh (ksh)
(root,964,960,0.0) -ksh (ksh)
(root,900,924,0.0) /bin/sh ./check_mk_agent
(root,664,676,0.0) ps -ax -o user
(root,536,1424,0.0) sed -e 1d -e s/ *\\([^ ]*\\) *\\([^ ]*\\) *\\([^ ]*\\
(root,520,24,0.0) /usr/libexec/getty std.9600 ttyC0
(root,508,24,0.0) /usr/libexec/getty std.9600 ttyC1
(root,516,24,0.0) /usr/libexec/getty std.9600 ttyC2
(root,520,24,0.0) /usr/libexec/getty std.9600 ttyC3
(root,512,24,0.0) /usr/libexec/getty std.9600 ttyC5
<<<cpu>>>
0.00 0.02 0.05 2/40 1
<<<uptime>>>
267705
<<<openbsd_mem>>>
MemTotal: 506736 kB
MemFree: 4252 kB
SwapTotal: 262144 kB
SwapFree: 238944 kB
<<<lnx_if:sep(58)>>>
em0: 0 0 0 0 0 0 0 0 0
1500: 0 0 0 0 0 0 0 0 0
<Link>: 0 0 0 0 0 0 0 0 0
00:0c:29:84:06:b9: 0 0 0 0 0 0 0 0 0
528211: 0 0 0 0 0 0 0 0 0
[em0]
Duplex: Half
Auto-negotiation: off
Address:
[1500]
Address:
[<Link>]
Address:
[00:0c:29:84:06:b9]
Address:
[528211]
Address:
[0]
Address:
