OPENSSL_3.2.0’ not found
CMK version: 2.2.0p47.cre - 2.4.0p17.cre
OS version: RHEL 9.7
Error message: OPENSSL_3.2.0’ not found
I installed check_mk on a Red Hat 9 Linux server.
I have two websites:
  • A production site (name = production_site) running version 2.2.0p47.cre. Everything is OK.
Test example with check url
$ /opt/omd/sites/production_site/local/lib/nagios/plugins/check_url.pl -u http://myurl
Application XYZ : All tests (7) are OK
  • A test site (name test_site) running version 2.4.0p17.cre. I’m getting errors : OPENSSL_3.2.0’ not found
The same command on the production site
$ /opt/omd/sites/test_site/local/lib/nagios/plugins/check_url.pl -u http://myurl
HTTP error: 501 Not Implemented (Can’t load ‘/usr/lib64/perl5/vendor_perl/auto/Net/SSLeay/SSLeay.so’ for module Net::SSLeay: /omd/sites/test_normandie/lib/libssl.so.3: version `OPENSSL_3.2.0’ not found (required by /usr/lib64/perl5/vendor_perl/auto/Net/SSLeay/SSLeay.so) (LWP::Protocol::https not installed))|t=0.076s;5;15;0;30
I saw that the problem was solved : Checkmk on RHEL 9.7 and/or RHEL 10.1 issues
with the following solution : Werk #18935: OpenSSL Upgrade Compatibility Fix
But this solution only corrects some commands, but not all cases.
do you have any idea
Regards
Stan
Not sure what you are asking. The Werk fixes some commands and explains how to do it yourself for arbitrary commands. We are working on a more stable approach, but that takes some time. So the current state is as documented in the Werk.
Thanks for your answer.
Ok, the Werk fixes some commands but I don’t see where he explains how to do it yourself for arbitrary commands…
Regards
Sorry, I had a follow-up Werk in mind: Werk #18937: Expanded System Command Wrappers for OpenSSL Compatibility
Hello, Thank you for the link.
I understand the solution you’ve provided, but I’m not sure how to apply it to my specific error.
Any ideas?
Regards
I think the Werk I shared says it all: If you want to use your own custom check, you need to create a wrapper script yourself.
Upgrading to version 2.5.0 resolved the “OPENSSL_3.2.0 not found” issue.
Thank you for this great work!
