Result could be like that - but on checkmk host itself
Prepare OPNsense
- Create API Keys under the user
- Create CRON to check for firmware updates
Prepare Checkmk
install jq
/usr/lib/check_mk_agent/local/omd_runner.sh
#!/bin/bash
runuser -l ***CHECKMKINSTANCE*** -c 'bash /usr/lib/check_mk_agent/local/lq_localcheck.sh'
Script itself
#!/bin/bash
#needs jq "yum install jq"
#https://www.predic8.de/jq-json-kommandozeile.htm
#https://jqplay.org/
#https://jsonformatter.org/json-parser
NAME="OPNSense"
key=" ***created key**** "
secret=" ***created secret*** "
firmwarestatusURL="https:// ***ipandporttoopensense*** /api/core/firmware/status"
RESULT=$(curl -s -k -u $key:$secret $firmwarestatusURL)
#echo $RESULT
COUNTUPDATES=$(echo $RESULT | jq '.upgrade_packages | length')
NAMEUPDATES=$(echo $RESULT | jq -r '[.upgrade_packages[].new_version] | join(", ")')
MESSAGE=$(echo $RESULT | jq -r '.status_msg')
if (($COUNTUPDATES < 1));
then
STATE="0"
else
STATE="1"
fi
echo "$STATE $NAME - $MESSAGE $NAMEUPDATES"
- List item
