CMK version: 2.0.0p12 (CEE) Enterprise Edition
**OS version:**Red Hat Enterprise Linux Server 7.7 (on Oracle database server)
Service configuration does not discover tablespaces and rman backup, all other Oracle services are discoverd.
Shutting down Oracle instance does not trigger a red CRIT status, only “the service is stale …” message.
Any idea what could be the reason?
Thank you.
can you please provide the output of the oracle sections and your DB version and if you are using RAC and/or ASM features? The output of MK_CONFDIR=/etc/check_mk/ /usr/lib/check_mk_agent/plugins/mk_oracle -t (may contains passwords) could also be handy.
Hi @tosch,
Oracle database is version 19.14, no ASM/RAC is configured.
What do you mean under oracle section. Find below mk_oracle output.
[root@cm-rtdb-p-02:~]>export MK_CONFDIR=/etc/check_mk
[root@cm-rtdb-p-02:~]>/usr/lib/check_mk_agent/plugins/mk_oracle -t
---login----------------------------------------------------------------
Operating System: Linux
ORACLE_HOME (oratab): /u01/app/oracle/product/19.0.0.0/db
Logincheck to Instance: cmrtdb
Version: 19.0
Login ok User: CHECKMK on cm-rtdb-p-02 Instance cmrtdb
SYNC_SECTIONS: instance sessions logswitches undostat recovery_area processes recovery_status longactivesessions dataguard_stats performance locks systemparameter
ASYNC_SECTIONS: tablespaces rman jobs resumable iostats
Thanks for recommendation. I changed MK_ORA_DEBUG=true, but unfortunatelly it still doesn’t work, the same issue again. Shutting down Oracle instance only reported stale status, tablespaces are not discoverd.
