On the virtual appliance, does Checkmk have any in-built way to route outgoing traffic through the Cluster IP from both nodes?
If not, is there a way to implement something like this to avoid changing local firewalls on all currently monitored client hosts to also include the failover server IP?
if i know correctly it should use floating IP address so you set your FW to that and it should work, but i dont have virtual-appliance so cannot be sure.
Best regards,
JF
For outgoing traffic the physical IP of the appliance is used. In a cluster you have to allow two IPs on your FW´s.
regards
Michael
Thank you very much. I do think a floating IP for outgoing traffic would be a helpful feature to provide, built-in, for customers making this sort of transition.
yes, that would be a really nice feature, especially as more parts are affected than local firewalls.
You also have to consider “central” firewalling, SNMP access, checkmk agent access, etc.
Exactly. There’s a lot that will need configuring. I’ll definitely be creating a request in the feature portal for this one. Hopefully we’ll see something before we have to go to production.
Somebody has already posted a request for this in the feature portal. Use cluster IP address for SNMP traffic - Checkmk. There’s also a comment there with a possible implementation. Anyone have thoughts on this? Will this be able to automatically handle the failover event? I will need to look into this some more. Thanks.
