Error message:Parsing of section huawei_wlc_aps failed
“exc_traceback”: [
“/omd/sites/check_mk/lib/python3/cmk/checkengine/sectionparser.py”,
117,
“_parse_raw_data”,
“return parse_function(list(raw_data))”
“/omd/sites/check_mk/share/check_mk/checks/huawei_wlc_aps”,
60,
“parse_huawei_wlc_aps”,
“ap_id, radio_state_2GHz, ch_usage_2GHz, users_online_2GHz = aps_info2[2 * idx]”
“exc_type”: “IndexError”,
“exc_value”: “list index out of range”,
“id”: “81414706-e307-11ef-87ea-9bb2d72acfa7”,
Hello, i see on the crash report all the data are correctly retrived but continue crashing on parsing. How can i solve it?
Just a little note: if your instance has internet access, I would recommend using the internal tool in the GUI to send the crash report directly – that way, if needed, it would be possible to contact you for more details based on the information sent together with the report.
Please only send crash reports to feedback@checkmk.com if your Checkmk does not have access to internet.
What I mean is that when the crash report is formed, you can send it from the GUI in Monitor > Crash reports > Select Crash report > Enter Name and Email Address > Submit report.
I checked, there is no email from you at the feedback@checkmk.com. If you can submit the report from the GUI that is enough though, no extra steps are needed
