I have 3 sites 1.6p27, 1 master and 2 slaves.
I am migrating master from physical centos8 to virtual redhat 8. Using omd backup and omd restore.
Activate pending changes fails on Slaves.
- Slave1
State: Failed. Started at: 12:07:48. Finished at: 12:09:41.
Failed: Garbled automation response:
Internal automation error: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
File "/omd/sites/cmkdc_slave01/lib/python/cmk/gui/wato/pages/automation.py", line 186, in _execute_automation_command
html.write(repr(automation.execute(automation.get_request())))
File "/omd/sites/cmkdc_slave01/lib/python/cmk/gui/watolib/sites.py", line 728, in execute
with store.lock_checkmk_configuration(), store.lock_cmk_base_configuration():
File "/omd/sites/cmkdc_slave01/lib/python2.7/contextlib.py", line 17, in __enter__
return self.gen.next()
File "/omd/sites/cmkdc_slave01/lib/python/cmk/utils/store.py", line 86, in lock_cmk_base_configuration
aquire_lock(path)
File "/omd/sites/cmkdc_slave01/lib/python/cmk/utils/store.py", line 349, in aquire_lock
fcntl.flock(fd, flags)
File "/omd/sites/cmkdc_slave01/lib/python/cmk/gui/htmllib.py", line 809, in handle_request_timeout
"issue is a bug, please send a crash report.") % duration)
RequestTimeout: Your request timed out after 110 seconds. This issue may be related to a local configuration problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
- slave2
State: Failed. Started at: 12:01:19. Finished at: 12:03:48.
Failed: Got invalid data:
File "/omd/sites/cmkdc_slave02/lib/python/cmk/gui/wato/pages/automation.py", line 186, in _execute_automation_command
File "/omd/sites/cmkdc_slave02/lib/python/cmk/gui/wato/pages/activate_changes.py", line 519, in execute
return cmk.gui.watolib.activate_changes.execute_activate_changes(request.domains)
File "/omd/sites/cmkdc_slave02/lib/python/cmk/gui/watolib/activate_changes.py", line 1285, in execute_activate_changes
warnings = domain_class().activate()
File "/omd/sites/cmkdc_slave02/lib/python/cmk/gui/watolib/config_domains.py", line 69, in activate
return check_mk_local_automation(config.wato_activation_method)
File "/omd/sites/cmkdc_slave02/lib/python/cmk/gui/watolib/automations.py", line 112, in check_mk_local_automation
outdata = p.stdout.read()
File "/omd/sites/cmkdc_slave02/lib/python/cmk/gui/htmllib.py", line 809, in handle_request_timeout
thx.
Dario.
