I’m trying to use the piggyback feature and have read the documentation https://checkmk.com/cms_piggyback.html, however, I don’t understand how to setup the piggyback host A to query host B to retrieve the CMK data from that agent.
Background is that host B is in an isolated network and host A is the bastion host that can be accessed by CMK. I can’t find any information on how to setup / configure host A to provide the CMK data of host B. Is there a config / agent or anything to use instead of the default CMK agent? What am I missing
One option is a small helper script on your host A that is only collecting the agent output data from host B and write it to a cache file (or retrieve it live).
This helper script only needs to add the piggyback line at the top and bottom.
Result should look like this.
This resulting text is then only outputted with the normal agent output from host A.
CMK then sees that it is data for host B and will display the services in your monitoring an the right host.
