2.1.0p30
Centos 7
8 vanished services
The script should run an the CheckMK server, but removes other services.
All local script services after that part are lost.
<<<<s3-sandbox-dev.interhyp-cloud.de>>>>
<<<local>>>
0 s3-sandbox-dev - okay
<<<local:sep(0)>>>
0 DNS_PTR_Entry - DNS PTR entry exists
0 Grub_Entries - Kernel entries in /etc/grub2-efi.cfg OK
0 Check_Locked_AD_Tech_Users - All Tech AD User OK
0 LLDPD - ethernet port patch status OK
0 Puppet_Agent time=328;360;600 agent 7.24.0 is running (run-time 328 seconds)
0 Veeam_Jobs - Job "0 Default - ehyp": SUCCESS;
0 Puppet_Env - Puppet Env: production
<<<local>>>
0 SSL_Certificate_monitoring.interhyp-intern.de - Certificate will expire on 2023-11-29 - SANs: DNS:demuc2-checkmk-prod1.interhyp-infralinuxdmz.de, DNS:monitoring.interhyp-intern.de
0 Vault_Agent - Vault agent ok
0 VAULT_READ - vault login is working - read works successfully ✅
0 Process_filebeat - 1 process ^/usr/share/filebeat/bin/filebeat[^-], 3847 MB virtual, 65 MB physical, running for 11 days
0 Process_goferd - 1 process /usr/bin/goferd, 283 MB virtual, 11 MB physical, running for 10:24:20 hours
0 Process_httpd - 18 process httpd
cached(1693888241,86400) 0 Kernel_Version - Kernel Version is 3.10.0-1160.95.1.el7.x86_64 check interval 86400 sec
cached(1693888254,86400) 0 Missing_Security_Updates - MISSING SECURITY UPDATES - but below delay - see long output for details\n\npython-syspurpose.x86_64 1.24.52-2.el7.centos centos7-updates\nsubscription-manager.x86_64 1.24.52-2.el7.centos centos7-updates\nsubscription-manager-rhsm.x86_64 1.24.52-2.el7.centos centos7-updates\nsubscription-manager-rhsm-certificates.x86_64\n 1.24.52-2.el7.centos centos7-updates
<<<logwatch>>>
Even this does not work. I lose services on the server, that runs the checkmk agent.
#!/bin/bash
echo "<<<<s3-sandbox-dev.interhyp-cloud.de>>>>"
echo "<<<local>>>"
echo "0 test - andreas"
echo "<<<<>>>>"
Storing piggyback data for: ‘s3-sandbox-dev.interhyp-cloud.de’
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/piggyback/s3-sandbox-dev.interhyp-cloud.de/demuc2-checkmk-prod1.interhyp-infralinuxdmz.de
Got lock on /omd/sites/prod/tmp/check_mk/piggyback/s3-sandbox-dev.interhyp-cloud.de/demuc2-checkmk-prod1.interhyp-infralinuxdmz.de
Releasing lock on /omd/sites/prod/tmp/check_mk/piggyback/s3-sandbox-dev.interhyp-cloud.de/demuc2-checkmk-prod1.interhyp-infralinuxdmz.de
Released lock on /omd/sites/prod/tmp/check_mk/piggyback/s3-sandbox-dev.interhyp-cloud.de/demuc2-checkmk-prod1.interhyp-infralinuxdmz.de
Received piggyback data for 1 hosts
Can somebody please help me?
