Piggyback for cluster host?
We are creating piggyback information via a spool file (created by an active check) on the monitoring server for a cluster host. The content of the piggyback can then be found in /omd/sites//tmp/check_mk/piggyback//.
But even after a while, I cannot find the new item at the cluster host.
Any idea what I may do wrong? or is that even possible? does the CheckPlugin of this item need to have a cluster check? Even when the piggyback data does not come from one of the cluster nodes?
