Hi there,
I hope you can help me out again.
After upgrade from 2.0.x → 2.1.x, I get the Warn mentioned in the title which concerns docker.
I followed the following guide:
I imported the python library, but that approach hasn’t solved the problem yet.
The giude states, that the directory /tmp/check_mk/piggyback should contain the files with docker id - and the files do exist.
But the log below states the following:
Got lock on /omd/sites/master/tmp/check_mk/piggyback/e02308fc412a/SERVER.dev.SERVER.biz
The rights were set as follows:
-rw-rw---- 1 master master 5.8K Feb 19 15:20 SERVER.dev.SERVER.biz
When I try to change the permission to - for example - 777, then everytime after i perform the above command, it will be set back to default.
Thank you for your help in advance
CMK version:
2.1.0p39.cre
OS version:
Debian 12
[piggyback] Missing data
Checkmk version 2.1.0p39
Trying to acquire lock on /omd/sites/master/var/check_mk/license_usage/next_run
Got lock on /omd/sites/master/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/master/var/check_mk/license_usage/history.json
Got lock on /omd/sites/master/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/master/var/check_mk/license_usage/history.json
Released lock on /omd/sites/master/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/master/var/check_mk/license_usage/next_run
Released lock on /omd/sites/master/var/check_mk/license_usage/next_run
+ FETCHING DATA
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7ff2e6b88730]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(SERVERdev.SERVER.biz, base_path=/omd/sites/master/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=90, inventory=90), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 42 sec, allowed is 0 sec)
Calling: ssh -p 10248 -l mon -i /etc/check_mk/check_mk.key SERVER-IP
Write data to cache file /omd/sites/master/tmp/check_mk/cache/SERVERdev.SERVER.biz
Trying to acquire lock on /omd/sites/master/tmp/check_mk/cache/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/cache/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/cache/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/cache/SERVERdev.SERVER.biz
[cpu_tracking] Stop [7ff2e6b88730 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=0.25, children_system=0.0, elapsed=4.879999998956919))]
[cpu_tracking] Start [7ff2e6b88a30]
[PiggybackFetcher] Fetch with cache settings: NoCache(SERVERdev.SERVER.biz, base_path=/omd/sites/master/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=90, inventory=90), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'SERVERdev.SERVER.biz'. Skip processing.
No piggyback files for 'SERVER-IP'. Skip processing.
[cpu_tracking] Stop [7ff2e6b88a30 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<ntp:cached(1708351630,120)>>> / Transition HostSectionParser -> HostSectionParser
<<<apt:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_info:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_info:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_disk_usage:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_disk_usage:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_images:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_images:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_network:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_node_network:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
PiggybackMarker(hostname='5789e84a5cc2') / Transition HostSectionParser -> PiggybackParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
Transition PiggybackSectionParser -> NOOPParser
PiggybackMarker(hostname='aa88f73b5baf') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') / Transition NOOPParser -> PiggybackParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_node_name'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_status'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_labels'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='60091b5df14b') SectionMarker(name=SectionName('docker_container_network'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='aa88f73b5baf') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='fa3688ff05d3') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='5789e84a5cc2') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='e02308fc412a') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='04cb49e8944f') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='10f9d1765301') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_mem'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_cpu'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='|') / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='c9fdb8f4e333') SectionMarker(name=SectionName('docker_container_diskstat'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator='\x00') / Transition PiggybackSectionParser -> PiggybackSectionParser
<<<mysql_ping>>> / Transition NOOPParser -> HostSectionParser
<<<netstat>>> / Transition HostSectionParser -> HostSectionParser
<<<port_check>>> / Transition HostSectionParser -> HostSectionParser
<<<sshfsmounts>>> / Transition HostSectionParser -> HostSectionParser
Trying to acquire lock on /omd/sites/master/var/check_mk/persisted/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/var/check_mk/persisted/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/var/check_mk/persisted/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/var/check_mk/persisted/SERVERdev.SERVER.biz
Stored persisted sections: lnx_packages, lnx_distro, lnx_cpuinfo, lnx_uname, lnx_ip_r, lnx_block_devices
Using persisted section SectionName('lnx_packages')
Using persisted section SectionName('lnx_distro')
Using persisted section SectionName('lnx_cpuinfo')
Using persisted section SectionName('lnx_uname')
Using persisted section SectionName('lnx_ip_r')
Using persisted section SectionName('lnx_block_devices')
-> Add sections: ['apt', 'check_mk', 'cifsmounts', 'cpu', 'df', 'diskstat', 'docker_node_disk_usage', 'docker_node_images', 'docker_node_info', 'docker_node_network', 'job', 'kernel', 'labels', 'lnx_block_devices', 'lnx_cpuinfo', 'lnx_distro', 'lnx_if', 'lnx_ip_r', 'lnx_packages', 'lnx_uname', 'local', 'md', 'mem', 'mounts', 'mysql_ping', 'netstat', 'nfsmounts', 'ntp', 'port_check', 'ps_lnx', 'sshfsmounts', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest']
No persisted sections
-> Add sections: []
Storing piggyback data for: '5789e84a5cc2'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/5789e84a5cc2/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/5789e84a5cc2/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/5789e84a5cc2/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/5789e84a5cc2/SERVERdev.SERVER.biz
Storing piggyback data for: 'aa88f73b5baf'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/aa88f73b5baf/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/aa88f73b5baf/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/aa88f73b5baf/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/aa88f73b5baf/SERVERdev.SERVER.biz
Storing piggyback data for: 'fa3688ff05d3'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/fa3688ff05d3/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/fa3688ff05d3/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/fa3688ff05d3/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/fa3688ff05d3/SERVERdev.SERVER.biz
Storing piggyback data for: '10f9d1765301'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/10f9d1765301/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/10f9d1765301/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/10f9d1765301/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/10f9d1765301/SERVERdev.SERVER.biz
Storing piggyback data for: '04cb49e8944f'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/04cb49e8944f/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/04cb49e8944f/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/04cb49e8944f/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/04cb49e8944f/SERVERdev.SERVER.biz
Storing piggyback data for: 'e02308fc412a'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/e02308fc412a/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/e02308fc412a/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/e02308fc412a/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/e02308fc412a/SERVERdev.SERVER.biz
Storing piggyback data for: 'c9fdb8f4e333'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/c9fdb8f4e333/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/c9fdb8f4e333/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/c9fdb8f4e333/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/c9fdb8f4e333/SERVERdev.SERVER.biz
Storing piggyback data for: '60091b5df14b'
Trying to acquire lock on /omd/sites/master/tmp/check_mk/piggyback/60091b5df14b/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/piggyback/60091b5df14b/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/piggyback/60091b5df14b/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/piggyback/60091b5df14b/SERVERdev.SERVER.biz
Received piggyback data for 8 hosts
[cpu_tracking] Start [7ff2e6b46a60]
value store: synchronizing
Trying to acquire lock on /omd/sites/master/tmp/check_mk/counters/SERVERdev.SERVER.biz
Got lock on /omd/sites/master/tmp/check_mk/counters/SERVERdev.SERVER.biz
Releasing lock on /omd/sites/master/tmp/check_mk/counters/SERVERdev.SERVER.biz
Released lock on /omd/sites/master/tmp/check_mk/counters/SERVERdev.SERVER.biz
APT Updates No updates pending for installation
CPU load 15 min load: 1.01, 15 min load per core: 0.17 (6 cores)
CPU utilization Total CPU: 15.34%
Check_MK Agent Version: 2.0.0p18, OS: linux
Disk IO SUMMARY Read: 0.00 B/s, Write: 176 kB/s, Latency: 1 millisecond
Docker containers Containers: 8, Running: 7, Paused: 0, Stopped: 1
Docker disk usage - buildcache Size: 3.09 GB, Reclaimable: 0.00 B, Count: 210, Active: 210
Docker disk usage - containers Size: 326.44 MB, Reclaimable: 0.00 B, Count: 8, Active: 7
Docker disk usage - images Size: 33.00 GB, Reclaimable: 28.07 GB, Count: 55, Active: 8
Docker disk usage - volumes Size: 0.00 B, Reclaimable: 0.00 B, Count: 12, Active: 1
Docker node info Daemon running on host wp
Filesystem / 67.89% used (19.93 of 29.36 GB), trend: -31.00 MB / 24 hours
Filesystem /mnt/dockerdisk 64.92% used (76.31 of 117.56 GB), trend: +57.04 MB / 24 hours
Kernel Performance Process Creations: 17.15/s, Context Switches: 6479.38/s, Major Page Faults: 0.02/s, Page Swap in: 0.00/s, Page Swap Out: 0.00/s
Memory Total virtual memory: 26.53% - 2.59 GB of 9.75 GB, 9 additional details available
Mount options of / Mount options exactly as expected
Mount options of /mnt/dockerdisk Mount options exactly as expected
Mount options of /mnt/storage/stor2 mount options exactly as expected
NTP Time Offset: -0.3510 ms, Stratum: 1, Jitter: 0.1923 ms, Time since last sync: 8 minutes 19 seconds
Systemd Service Summary Total: 114, Disabled: 3, Failed: 0
[cpu_tracking] Stop [7ff2e6b46a60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
[agent] Success, [piggyback] Missing data(!), execution time 4.9 sec | execution_time=4.900 user_time=0.000 system_time=0.010 children_user_time=0.250 children_system_time=0.000 cmk_time_ds=4.620 cmk_time_agent=0.010
