Ping check in checkmk
Is there any way we can change the Ping check time as i believe it executes every 15sec but if i want to change it to 30 sec where can i do,i am not able to find it in host & service parameters and also in global settings
Do you use the Entperise or RAW edition. If it is the RAW then the default ping is executed one time per minute with 5 ICMP packets sent at the same time. If it is the Enterprise with smart ping then there will be sent one ICMP packet every 6 seconds and the system expects one packet in return in a 15 seconds time frame.
the enterprise edition
If i want to change the expectation time from 15sec to 30 sec in enterprise edition is it possible
The normal host check interval can be changed by yourself without a problem.
