Pinging Delay on Notification
I am attempting to setup alerting using Smart Ping, I’ve set the “Settings for host checks” set to 600 seconds so it alerts only after 10 minutes. Though it doesnt seem to function as it only blocks some alerts, it keeps alerting with 100% nan errors, then it alerts when it comes back online.
The simple thing I am looking to do is to only alert when a device is offline for more than 10 minutes, and to not alert if it comes back online unless its been off for longer than 10 minutes. Any idea how do to do so, or what I’m doing wrong here?
Setup the Smart Ping isn’t the right choice for this and you should first revert this setting. What you can do is make use of The Delay host notifications and Delay service notifications rule sets.
Do you know what it is I should do instead of smart ping?
