Danielg45
(Daniel Guerra)
October 12, 2020, 11:21am
1
Buen día!
Al generar reporte con el PDF me muestra el siguiente error:
Please check the documentation for information about the following error.
Function get_magic_quotes_runtime() is deprecated
file [line]:
application/vendor/fpdf/fpdf.php [1043]:
Gracias por el apoyo!
The fpdf library inside PNP4Nagios is to old for actual PHP versions.
For the magic_quotes problem there are some solutions like this.
I don’t know if this is the only problem with newer PHP versions.
Danielg45
(Daniel Guerra)
October 12, 2020, 3:21pm
3
Hola Andreas-doehler!
Gracias por el apoyo, la solución que me indicas no es para el error que estoy presentando.
Saludos!
It’s the same error only other part of PNP4Nagios. You can use the solution from there at the problematic code from your error. But it is possible that other errors also occur.
Danielg45
(Daniel Guerra)
October 12, 2020, 10:50pm
5
Andreas-doehler! Thanks for the support and collaboration.
best regards.
system
(system)
Closed
October 12, 2021, 10:50pm
6
