I am trying to improve some pnp graphs for some builtin checks and nagios plugins and local checks, but I am a bit confused, I am wondering how check-mk-raw creates the pnp graphs using rrdtools? I found several locations for the php templates:
- /omd/versions/1.6.0p6.cre/share/check_mk/pnp-templates/
- /omd/versions/1.6.0p6.cre/share/pnp4nagios/htdocs/templates.dist/
- /omd/sites/ {sitename} /etc/pnp4nagios/templates/
So I have several questions please:
- How are the php files related in these directories?
- are the builtin checks located at /opt/omd/versions/1.6.0p6.cre/share/check_mk/checks/ or at /opt/omd/sites/ {sitename} /share/check_mk/checks/ ? and how are they related (obviously they are the same)?
- Which templates are usedto create the graphs for the builtin checks?
- Which templates are usedto create the graphs for the nagios plugins?
- Which templates are used to create the graphs for local checks?
Beside that I would like to know:
- how does check-mk knows which template is to be used for which check? (where is it implemented)
- Is it OK to modify builtin checks according to my needs? if yes which ones? those in /omd/sites or /omd/versions?
- Is it OK to modify builtin templates according to my needs? if yes which ones? those in pnp-templates or in templates.dist? or is it better to create a new check and template? and where to place them (checks as well as templates)?
I appreciate any help on this, a link to the documentation will be helpful as well.
Thanks a lot.
