I am Using Checkmk 2.1 and i am Monitoring 9 Hosts. Most of them are about an year old and Debian 11. Before Updating to 2.1 everything works fine. Now there is the Message: „Host is registered for TLS but not using it“
I Unterstand the Problem and know that ist possible to Use the Legacy Mode.
So i See that systemd is listening on the Port, if i kill the Process and Install the Agent everything is Fine, and i can Connect it to my Checkmk Server.
After a Restart Systemd is using it again.
Is it possible to Tell systemd NOT to Listen on this Port?
Or is the only Solution to Use the Legacy Mode?
When upgrading from 2.0 or earlier, try purging the agent package and reinstalling it.
That fixed an update-related problem for me, but I don’t remember if it was that one
