Possible to Monitor POP3 Mailboxes?
Hello experts,
We are looking to monitor the contents of several POP3 mailboxes. We are aware of the check_mail plugin, but it only checks to ensure that login is possible and, optionally, processes messages by passing them to the event console:
We are also aware of the check_mailboxes plugin, which seems to do what we want but only supports IMAP or EWS protocols:
Is there anything like the check_mailboxes plugin that supports POP3?
Thanks in advance,
Jason
You could use check_pop3_account.
Thank you for the suggestion Robert.
I will need to do some research to figure out how to install/use Nagios Exchange plugins with Checkmk.
Regards,
Jason
Put the executable Nagios plugin in $OMD_ROOT/local/lib/nagios/plugins and use the ruleset “Integrate Nagios plugins” to create a service check.
Or put the Nagios plugin on the host itself and use MRPE via the agent to call it.
You might want to look here (deep link):
