i used the Plugin NVIDIA-GPU from Smraju a about an month. Great plugin, monitors temperature, GPU, fan, power and memory. Since the update to Nvidia driver 535.54.03, the monitoring of the power consumption unfortunately no longer works. An update would be necessary.
But probably it would be enough to rewrite the agent plugin. Here I have the error message.
PythonArgs: ['./nvidia-smi']
Traceback:
File "/usr/lib/check_mk_agent/plugins/./nvidia-smi", line 86, in <module>
power_draw = float(gpu
IndexError: list index out of range
In the code itself the whole thing looks like this:
So if you change it as below then all the elements have their correct names:
(small change: max_power_limit is used as power_limit is not existing any more)
