New to checkmk but been using Nagios for quite a while and adding a server into checkmk I get an error from the Nagios config about illegal characters in the service name - I think because there are () in the name, and it therefore fails and states it has output it to check_mk_objects_cfg.broken.
I had thought maybe I fix this by editing the check_mk_objects.cfg file but when I look in that file, this new host isn’t in there so I assume it has not added it because of the error.
As that would be how I would normally fix something in Nagios, byjust editing the service name, and as the new host is only visible in the .broken file, do I fix the .broken file and use it to overwrite the .cfg file?
As new to this just don’t want to screw it up too much
Inside a major release you mostly can’t switch between the patches easily. So a downgrade to p13 could also fix your problem.
Let us know, if it fixes your problem and please mark the topic with a solution.
