It is not possible to like my post, or more importantly to apply the suggestion on your server?
In case of the latter, perhaps you can post more information of your situation, edition / version / screenshots / why suggestion does not work. So we can better understand and hopefully help out.
I was looking for a way to set a host label based if a service was running on a host
for example, I’m having issues detecting if IIS is installed
HW/SW most of the time doesn’t report if IIS is installed so I was thinking if the host has for example W3SVC running I can set a host label on that condition, but the condition
You get confused with the term service being used double and triple here.
The “Service” in the predefined conditions refers to the Checkmk service name. It is not a Windows service.
You can use the ruleset “Windows service discovery” to create service checks that monitor single Windows services.
Our you use the ruleset “Process discovery” to look for the IIS processes. With a rule here you can also create a host label that tells you that IIS is installed (because there is a running process on that host).
I will surely try this but why can’t I do this for a windows service, as the service is daemonized while a process is just check of a process is running and a windows service is explicitly instaled by an admin requesting for IIS …
EDIT: it looks like I cannot specify this kind of condition when setting host labels …
