CMK version: 2.2.0p22
OS version: Docker 2.2.0p22
Error message: 502 Bad Gateway
Hi everyone i deploy checkmk as containe
i change the default port to 8081>5000 and 8010>8000
This is the Nginx Proxy manager Host i add:
Enter “8081” into “Forward Port” and it will work.
Hi Simon
Enter the name or IP of your docker host then, instead of monitoring.
I see that it’s working now for you
(Your hostname was not blurred really well )
Good job!
Pubishing your checkmk server on the internet is generally not a good idea…
How did you see?
i remove the screenshoot if you tell me that is not blurred.
Btw i fix just attach the nginx docker network to checkmk container.
As Simon said…it is not blurred very well I was also able to catch the UR>L…
ok so please remove screenshoot for privacy, thanks.
