I cant configure snmp hosts in new cmk 2.0.0:
OMD[prueba]:~$ cmk --debug -vvI SAI-PNSTND
Discovering services and host labels on: SAI-PNSTND
SAI-PNSTND:
+ FETCHING DATA
[cpu_tracking] Start [7fb59be03910]
Connecting via TCP to 10.11.30.81:6556 (5.0s timeout)
[cpu_tracking] Stop [7fb59be03910 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=5.010000001639128))]
Try aquire lock on /omd/sites/prueba/var/check_mk/crashes/base/79affec8-8321-11eb-91c1-b11a8a4bb464/crash.info
Got lock on /omd/sites/prueba/var/check_mk/crashes/base/79affec8-8321-11eb-91c1-b11a8a4bb464/crash.info
Releasing lock on /omd/sites/prueba/var/check_mk/crashes/base/79affec8-8321-11eb-91c1-b11a8a4bb464/crash.info
Released lock on /omd/sites/prueba/var/check_mk/crashes/base/79affec8-8321-11eb-91c1-b11a8a4bb464/crash.info
File "/omd/sites/prueba/bin/cmk", line 92, in <module>
File "/omd/sites/prueba/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/prueba/lib/python3/cmk/base/modes/check_mk.py", line 1515, in mode_discover
discovery.do_discovery(
File "/omd/sites/prueba/lib/python3/cmk/base/discovery.py", line 367, in do_discovery
fetcher_messages=list(
File "/omd/sites/prueba/lib/python3/cmk/base/checkers/_checkers.py", line 246, in fetch_all
raw_data = source.fetch()
File "/omd/sites/prueba/lib/python3/cmk/base/checkers/_abstract.py", line 162, in fetch
with self._make_fetcher() as fetcher:
File "/omd/sites/prueba/lib/python3/cmk/fetchers/_base.py", line 189, in __enter__
self.open()
File "/omd/sites/prueba/lib/python3/cmk/fetchers/tcp.py", line 73, in open
self._socket.connect(self.address)
socket.timeout: timed out
OMD[prueba]:~$ cmk D SAI-PNSTND
execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
OMD[prueba]:~$ ^C
OMD[prueba]:~$ cmk -D SAI-PNSTND
SAI-PNSTND
Addresses: 10.11.30.81
Tags: [address_family:ip-v4-only], [agent:cmk-agent], [criticality:prod], [ip-v4:ip-v4], [networking:lan], [piggyback:auto-piggyback], [site:prueba], [snmp:snmp], [snmp_ds:snmp-v1], [tcp:tcp]
Labels:
Host groups: check_mk
Contact groups: check-mk-notify, all
Agent mode: Normal Checkmk agent, or special agent if configured
Type of agent:
TCP: 10.11.30.81:6556
SNMP (Community: 'F1n3tw0rk', Bulk walk: no, Port: 161, Backend: Classic)
Process piggyback data from /omd/sites/prueba/tmp/check_mk/piggyback/SAI-PNSTND
Services:
checktype item params description groups
OMD[prueba]:~$ cmk --debug -vvn SAI-PNSTND
Checkmk version 2.0.0
Try aquire lock on /omd/sites/prueba/var/check_mk/license_usage/next_run
Got lock on /omd/sites/prueba/var/check_mk/license_usage/next_run
Try aquire lock on /omd/sites/prueba/var/check_mk/license_usage/history.json
Got lock on /omd/sites/prueba/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/prueba/var/check_mk/license_usage/history.json
Released lock on /omd/sites/prueba/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/prueba/var/check_mk/license_usage/next_run
Released lock on /omd/sites/prueba/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7fcd719eb640]
[cpu_tracking] Stop [7fcd719eb640 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=5.009999997913837))]
Try aquire lock on /omd/sites/prueba/var/check_mk/crashes/base/e69b4d88-8323-11eb-91c1-b11a8a4bb464/crash.info
Got lock on /omd/sites/prueba/var/check_mk/crashes/base/e69b4d88-8323-11eb-91c1-b11a8a4bb464/crash.info
Releasing lock on /omd/sites/prueba/var/check_mk/crashes/base/e69b4d88-8323-11eb-91c1-b11a8a4bb464/crash.info
Released lock on /omd/sites/prueba/var/check_mk/crashes/base/e69b4d88-8323-11eb-91c1-b11a8a4bb464/crash.info
File "/omd/sites/prueba/bin/cmk", line 98, in <module>
exit_status = modes.call("--check", None, opts, args)
File "/omd/sites/prueba/lib/python3/cmk/base/modes/check_mk.py", line 1616, in mode_check
return checking.do_check(
File "/omd/sites/prueba/lib/python3/cmk/base/decorator.py", line 37, in wrapped_check_func
status, infotexts, long_infotexts, perfdata = check_func(hostname, *args, **kwargs)
File "/omd/sites/prueba/lib/python3/cmk/base/checking.py", line 195, in do_check
fetcher_messages = list(
self.open()
OMD[prueba]:~$
