Problem udpating version 2.0.0p37.cre to 2.1.0p30.cre
Hello I have a problem with update from newest 2.0.0 to 2.1
omd -vvvvv update
Saving temporary filesystem contents…OK
Unmounting temporary filesystem…OK
Cleaning up tmp directory…OK
2023-07-26 12:46:18 - Updating site ‘***’ from version 2.0.0p37.cre to 2.1.0p30.cre…
  • Installed dir var/log/agent-receiver
  • Identical new etc/omd
  • Updated etc/init.d/pnp_gearman_worker
  • Installed file etc/init.d/agent-receiver
  • Updated etc/init.d/xinetd
  • Permissions 0755 → 0775 etc/init.d/mkeventd
  • Updated etc/init.d/redis
  • Updated etc/init.d/stunnel
  • Updated etc/apache/conf.d/omd.conf
  • Updated etc/apache/conf.d/security.conf
  • Updated etc/apache/conf.d/01_wsgi.conf
  • Updated etc/apache/conf.d/02_fcgid.conf
  • Updated etc/cron.d/cmk_discovery
  • Installed file etc/cron.d/cmk_cleanup_pdf_tmp_files
  • Installed file etc/logrotate.d/agent_bakery
  • Installed file etc/logrotate.d/agent-registration
  • Installed file etc/logrotate.d/agent-receiver
  • Installed link etc/rc.d/10-agent-receiver
  • Installed file etc/omd/allocated_ports
  • Updated etc/nagvis/apache.conf
  • Installed dir etc/stunnel/conf.d
  • Updated etc/stunnel/server.conf
  • Installed file etc/stunnel/conf.d/01-livestatus.conf
  • Updated etc/check_mk/apache.conf
  • Installed file etc/mk-livestatus/livestatus@.service
  • Installed file etc/mk-livestatus/livestatus.socket
  • Updated etc/mk-livestatus/nagios.cfg
  • Updated etc/nagios/conf.d/check_mk_templates.cfg
  • Updated etc/nagios/nagios.d/misc.cfg
  • Vanished etc/nagios/conf.d/jmx4perl_nagios.cfg
  • Vanished etc/jmx4perl/config/websphere/threads.cfg
  • Vanished etc/jmx4perl/config/websphere/http.cfg
  • Vanished etc/jmx4perl/config/websphere/jdbc.cfg
  • Vanished etc/jmx4perl/config/websphere/jms.cfg
  • Vanished etc/jmx4perl/config/websphere/appstate.cfg
  • Vanished etc/jmx4perl/config/websphere/jca.cfg
  • Vanished etc/jmx4perl/config/glassfish.cfg
  • Vanished etc/jmx4perl/config/threads.cfg
  • Vanished etc/jmx4perl/config/common.cfg
  • Vanished etc/jmx4perl/config/websphere.cfg
  • Vanished etc/jmx4perl/config/jboss.cfg
  • Vanished etc/jmx4perl/config/tomcat.cfg
  • Vanished etc/jmx4perl/config/jetty.cfg
  • Vanished etc/jmx4perl/config/weblogic.cfg
  • Vanished etc/jmx4perl/config/metrics.cfg
  • Vanished etc/jmx4perl/config/memory.cfg
  • Vanished etc/jmx4perl/config/jboss7.cfg
  • Vanished .j4p
    Calling hook: /omd/versions/2.1.0p30.cre/lib/omd/hooks/AGENT_RECEIVER default
    Calling hook: /omd/versions/2.1.0p30.cre/lib/omd/hooks/AGENT_RECEIVER_PORT default
    File “/omd/versions/2.1.0p30.cre/bin/omd”, line 63, in
    omdlib.main.main()
    File “/omd/versions/2.1.0p30.cre/lib/python3/omdlib/main.py”, line 4685, in main
    command.handler(version_info, site, global_opts, args, command_options)
    File “/omd/versions/2.1.0p30.cre/lib/python3/omdlib/main.py”, line 2818, in main_update
    initialize_site_ca(site)
    File “/omd/versions/2.1.0p30.cre/lib/python3/omdlib/main.py”, line 1307, in initialize_site_ca
    root_ca=RootCA.load_or_create(root_cert_path(ca_path), f"Site ‘{site.name}’ local CA"),
    File “/omd/versions/2.1.0p30.cre/lib/python3/cmk/utils/certs.py”, line 52, in load_or_create
    return cls.load(path)
    File “/omd/versions/2.1.0p30.cre/lib/python3/cmk/utils/certs.py”, line 47, in load
    return cls(*load_cert_and_private_key(path))
    File “/omd/versions/2.1.0p30.cre/lib/python3/cmk/utils/certs.py”, line 101, in load_cert_and_private_key
    load_pem_private_key(
    File “/omd/versions/2.1.0p30.cre/lib/python3.9/site-packages/cryptography/hazmat/primitives/serialization/base.py”, line 18, in load_pem_private_key
    return backend.load_pem_private_key(data, password)
    File “/omd/versions/2.1.0p30.cre/lib/python3.9/site-packages/cryptography/hazmat/backends/openssl/backend.py”, line 1244, in load_pem_private_key
    return self._load_key(
    File “/omd/versions/2.1.0p30.cre/lib/python3.9/site-packages/cryptography/hazmat/backends/openssl/backend.py”, line 1475, in _load_key
    self._handle_key_loading_error()
    File “/omd/versions/2.1.0p30.cre/lib/python3.9/site-packages/cryptography/hazmat/backends/openssl/backend.py”, line 1517, in _handle_key_loading_error
    raise ValueError(
    ValueError: Could not deserialize key data. The data may be in an incorrect format or it may be encrypted with an unsupported algorithm.
solved
the issue was not proper file /omd/sites/XXX/etc/ssl/ca.pem
what is wired it was changed in 2019 and since then many updates went without issue
