CMK version: 2.1.0.cre
OS version: Rocky 8.7
Error message: Internal error: init() got an unexpected keyword argument ‘csrf_token’
Did a normal “omd update” on a new site (to test the update) but it somehow failed along the way:
2022-12-09 14:26:30 - Updating site 'test3' from version 2.0.0p31.cre to 2.1.0.cre...
* Updated .profile
* Identical new etc/omd
* Installed file etc/apache/apache-own.conf
* Updated etc/apache/conf.d/01_wsgi.conf
* Updated etc/apache/conf.d/02_fcgid.conf
* Updated etc/apache/conf.d/omd.conf
* Updated etc/apache/conf.d/security.conf
* Updated etc/check_mk/apache.conf
* Installed file etc/init.d/agent-receiver
* Permissions 0755 -> 0775 etc/init.d/mkeventd
* Updated etc/init.d/pnp_gearman_worker
* Updated etc/init.d/redis
* Updated etc/init.d/stunnel
* Updated etc/init.d/xinetd
* Installed file etc/logrotate.d/agent-receiver
* Installed file etc/logrotate.d/agent-registration
* Installed file etc/mk-livestatus/livestatus.socket
* Installed file etc/mk-livestatus/livestatus@.service
* Updated etc/mk-livestatus/nagios.cfg
* Updated etc/nagios/conf.d/check_mk_templates.cfg
* Updated etc/nagios/nagios.d/misc.cfg
* Updated etc/nagvis/apache.conf
* Installed file etc/omd/allocated_ports
* Installed link etc/rc.d/10-agent-receiver
* Installed dir etc/stunnel/conf.d
* Updated etc/stunnel/server.conf
* Installed file etc/stunnel/conf.d/01-livestatus.conf
* Installed dir var/log/agent-receiver
* Vanished etc/nagios/conf.d/jmx4perl_nagios.cfg
* Vanished etc/jmx4perl/config/websphere/appstate.cfg
* Vanished etc/jmx4perl/config/websphere/http.cfg
* Vanished etc/jmx4perl/config/websphere/jca.cfg
* Vanished etc/jmx4perl/config/websphere/jdbc.cfg
* Vanished etc/jmx4perl/config/websphere/jms.cfg
* Vanished etc/jmx4perl/config/websphere/threads.cfg
* Vanished etc/jmx4perl/config/common.cfg
* Vanished etc/jmx4perl/config/glassfish.cfg
* Vanished etc/jmx4perl/config/jboss.cfg
* Vanished etc/jmx4perl/config/jboss7.cfg
* Vanished etc/jmx4perl/config/jetty.cfg
* Vanished etc/jmx4perl/config/memory.cfg
* Vanished etc/jmx4perl/config/metrics.cfg
* Vanished etc/jmx4perl/config/threads.cfg
* Vanished etc/jmx4perl/config/tomcat.cfg
* Vanished etc/jmx4perl/config/weblogic.cfg
* Vanished etc/jmx4perl/config/websphere.cfg
* Vanished .j4p
Creating temporary filesystem /omd/sites/test3/tmp...OK
Executing update-pre-hooks script "01_mkp-disable-outdated"...OK
Executing update-pre-hooks script "02_cmk-update-config"...
-| Initializing application...
-| Updating Checkmk configuration...
-| ATTENTION: Some steps may take a long time depending on your installation, e.g. during major upgrades.
-| 1/24 Rewriting password store...
-| 2/24 Migrate Visuals context...
-| 3/24 Migrate dashlets...
-| 4/24 Update global settings...
-| 5/24 Rewriting tags...
-| 6/24 Rewriting hosts and folders...
-| 7/24 Rewriting rulesets...
-| Replacing ruleset non_inline_snmp_hosts with snmp_backend_hosts
-| 8/24 Rewriting autochecks...
-| 9/24 Cleanup version specific caches...
-| 10/24 Migrating fs_used name...
-| 11/24 Migrate pagetype topics...
-| 12/24 Migrate LDAP connections...
-| 13/24 Rewrite BI Configuration...
-| Skipping conversion of bi.mk (already done)
-| 14/24 Set version specific user attributes...
-| + "Set version specific user attributes" failed
-| Traceback (most recent call last):
-| File "/omd/sites/test3/lib/python3/cmk/update_config.py", line 237, in run
-| step_func()
-| File "/omd/sites/test3/lib/python3/cmk/update_config.py", line 1219, in _adjust_user_attributes
-| users: Users = load_users(lock=True)
-| File "/omd/sites/test3/lib/python3/cmk/gui/userdb.py", line 890, in load_users
-| val = load_custom_attr(uid, attr, conv_func)
-| File "/omd/sites/test3/lib/python3/cmk/gui/userdb.py", line 930, in load_custom_attr
-| return conv_func(result.strip())
-| File "/omd/sites/test3/lib/python3/cmk/gui/userdb.py", line 636, in _convert_session_info
-| return {k: SessionInfo(**v) for k, v in ast.literal_eval(value).items()}
-| File "/omd/sites/test3/lib/python3/cmk/gui/userdb.py", line 636, in <dictcomp>
-| TypeError: __init__() got an unexpected keyword argument 'csrf_token'
-| 15/24 Rewriting inventory data...
-| Skipping path '/omd/sites/test3/var/check_mk/inventory' (empty)
-| Skipping path '/omd/sites/test3/var/check_mk/inventory_archive' (empty)
-| Skipping path '/omd/sites/test3/tmp/check_mk/status_data' (empty)
-| Finished checking for corrupt files
-| Creating file '/omd/sites/test3/var/check_mk/update_config/py2conversion.done'
-| 16/24 Migrate audit log...
-| No audit log present. Skipping.
-| 17/24 Sanitize audit log (Werk #13330)...
-| Wrote audit log backup to /omd/sites/test3/audit_log_backup. Please check if the audit log in the GUI works as expected. In case of problems you can copy the backup files back to /omd/sites/test3/var/check_mk/wato/log. Please check the corresponding files in /omd/sites/test3/var/check_mk/wato/log for any leftover passwords and remove them if necessary. If everything works as expected you can remove the backup. For further details please have a look at Werk #13330.
-| Sanitizing log files: /omd/sites/test3/var/check_mk/wato/log/wato_audit.log
-| Finished sanitizing log files
-| Wrote sanitization flag file /omd/sites/test3/var/check_mk/wato/log/.werk-13330
-| 18/24 Rename discovered host label files...
-| 19/24 Rewriting host, service or contact groups...
-| 20/24 Rewriting notification configuration for ServiceNow...
-| 21/24 Renewing certificates without server name extension...
-| Copied certificate to /omd/sites/test3/etc/ssl/sites/test3.pem.bak
-| Creating new certificate...
-| 22/24 Adding site CA to trusted CAs...
-| 23/24 Rewrite mknotifyd config for central site...
-| 24/24 Rewriting InfluxDB connections...
-| Done
ERROR (exit code: 1)
Updating core configuration...
Generating configuration for core (type nagios)...
Precompiling host checks...OK
Finished update.
