CMK version: 2.0.0p33 to 2.1.0p22
OS version: Ubuntu Server 20.04
OMD[site]:~$ cmk-update-config -v
Initializing application...
ERROR: Please repair this and run "cmk-update-config -v" BEFORE starting the site again.
File "/omd/sites/site/lib/python3/cmk/update_config.py", line 2186, in main
has_errors = UpdateConfig(logger, arguments).run()
File "/omd/sites/site/lib/python3/cmk/update_config.py", line 298, in run
self._initialize_base_environment()
File "/omd/sites/site/lib/python3/cmk/update_config.py", line 375, in _initialize_base_environment
cmk.base.config.load_all_agent_based_plugins(cmk.base.check_api.get_check_api_context)
File "/omd/sites/site/lib/python3/cmk/base/config.py", line 1528, in load_all_agent_based_plugins
errors.extend(load_checks(get_check_api_context, filelist))
File "/omd/sites/site/lib/python3/cmk/base/config.py", line 1680, in load_checks
return _extract_agent_and_snmp_sections(
File "/omd/sites/site/lib/python3/cmk/base/config.py", line 2120, in _extract_agent_and_snmp_sections
create_snmp_section_plugin_from_legacy(
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/__init__.py", line 246, in create_snmp_section_plugin_from_legacy
detect_spec = create_detect_spec(
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 416, in create_detect_spec
_compute_detect_spec(
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 392, in _compute_detect_spec
return _ast_convert_dispatcher(expression_ast)
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 342, in _ast_convert_dispatcher
return _ast_convert_compare(arg)
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/register/section_plugins_legacy/convert_scan_functions.py", line 242, in _ast_convert_compare
return not_equals(
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/utils.py", line 208, in not_equals
return _negate(equals(oidstr, value))
File "/omd/sites/site/lib/python3/cmk/base/api/agent_based/utils.py", line 166, in equals
return SNMPDetectSpecification([[(oidstr, "%s" % re.escape(value), True)]])
File "/omd/sites/site/lib/python3.9/re.py", line 277, in escape
pattern = str(pattern, 'latin1')
TypeError: decoding to str: need a bytes-like object, NoneType found
OMD[site]:~$
I’m trying to update CheckMK Enterprise from 2.0 to 2.1 but i always get this error message.
It’s telling me, there is an error that by parsing a regex there is a none-object instead of a string. It tells me to repair this, but i can’t find the source for this error. What shall be repaired?
A search in the forum doesn’t provide me any solution for this.
So your help is very apreciated.
Thanks in advance!
