Prior versions were functional e.g. version 2.0.0p18
Now when executing agent_netapp i get following error
CMK version:
2.1.0b5
OS version:
Ubuntu 20.04 LTS
######## START QUERY ########
<?xml version="1.0" ?>
<netapp xmlns="http://www.netapp.com/filer/admin" version="1.8" nmsdk_language="Python" nmsdk_version="5.2">
<system-get-version/>
</netapp>
<<<netapp_api_connection>>>
Agent Exception (contact developer): Unicode strings with encoding declaration are not supported. Please use bytes input or XML fragments without declaration.
File "/opt/omd/versions/2.1.0b5.cee/share/check_mk/agents/special/./agent_netapp", line 12, in <module>
sys.exit(main())
File "/omd/sites/cn_central/lib/python3/cmk/special_agents/agent_netapp.py", line 1743, in main
netapp_mode = fetch_netapp_mode(args, server)
File "/omd/sites/cn_central/lib/python3/cmk/special_agents/agent_netapp.py", line 851, in fetch_netapp_mode
version_info = query(args, server, "system-get-version", return_toplevel_node=True)
File "/omd/sites/cn_central/lib/python3/cmk/special_agents/agent_netapp.py", line 675, in query
response = server.get_response([what])
File "/omd/sites/cn_central/lib/python3/cmk/special_agents/agent_netapp.py", line 306, in get_response
netapp_response = NetAppResponse(response, self.debug)
File "/omd/sites/cn_central/lib/python3/cmk/special_agents/agent_netapp.py", line 426, in __init__
self.content = NetAppNode(ET.fromstring(self.raw_response_text))
File "src/lxml/etree.pyx", line 3252, in lxml.etree.fromstring
File "src/lxml/parser.pxi", line 1907, in lxml.etree._parseMemoryDocument
ValueError: Unicode strings with encoding declaration are not supported. Please use bytes input or XML fragments without declaration.
Checkmk version 2.1.0b5
Trying to acquire lock on /omd/sites/cn_central/var/check_mk/license_usage/next_run
Got lock on /omd/sites/cn_central/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/cn_central/var/check_mk/license_usage/history.json
Got lock on /omd/sites/cn_central/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cn_central/var/check_mk/license_usage/history.json
Released lock on /omd/sites/cn_central/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cn_central/var/check_mk/license_usage/next_run
Released lock on /omd/sites/cn_central/var/check_mk/license_usage/next_run
