Problem with notifications.mk when uprading to checkmk-2.4
CMK version: 2.3.0p34
OS version: Debian 11 (Bullseye)
Error message:Validating configuration files…
Upgrade vom 2.3.0p34 to 2.4.0p04 produces the following warning.
Seems there is a problem with the config file: netc/check_mk/conf.d/wato/notifications.mk
For additional information on the deprecation of the HTTP plug-in see the werk #17665.
-|  30/32 Validating configuration files...
-|        We have identified an issue with the configuration of your site.
-|        Currently, this is a warning to make you aware of a potential problem.
-|        Our validation process checks your configuration files against a work-in-progress internal representation.
-|        In this case, we found at least one mismatch between the two.
-|        For now you can proceed with the update of your site.
-|        However, in the future we will treat this as an error and stop the update procedure.
-|        To prevent any interruptions, we kindly ask you to notify us about this issue.
-|        Please send us a support ticket if you believe there are no issues with your relevant configuration mk files.
-|        Be sure to include the name of the configuration file, the displayed error message and
-|        if possible the mk file itself.
-|        This information will help us investigate further and determine whether improvements are needed.
-|        The following mk files had issues during the validation:
-|          etc/check_mk/conf.d/wato/notifications.mk................... Failed
-|      42 config errors
-|      {'input': {'bulk_sort_order': 'newest_first',
-|                 'elements': ['omdsite',
-|                              'address',
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                 'from': {'address': 'it@xxx.yyy.privat'},
-|                 'url_prefix': {'manual': 'http://xxx.yyy.privat/it/check_mk/'}},
-|       'loc': (0, 'notify_plugin', 1),
-|       'msg': 'Input should be a valid string',
-|       'type': 'string_type',
-|       'url': 'https://errors.pydantic.dev/2.10/v/string_type'}
-|                 'elements': ['address',
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (1, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (2, 'notify_plugin', 1),
-|      {'input': {'elements': ['address',
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (3, 'notify_plugin', 1),
-|      {'input': {'elements': ['address', 'abstime', 'longoutput', 'perfdata'],
-|                 'insert_html_section': '<HTMLTAG><a '
-|                                        'href="https://wiki.xxx.de/it-physik/doku.php?id=internal:hwg_ste2#sicherheit_dass_die_temperatur_ueberwacht_wird">HIER</a> '
-|                                        'findest du '
-|                                        'Hintergrundinformation!!!</HTMLTAG>\n',
-|                 'service_subject': 'Something has happened to cronjob script that '
-|                                    'oversees whether serverroom temperature is '
-|                                    'being monitored'},
-|       'loc': (4, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                 'service_subject': 'Check_MK: $HOSTNAME$/$SERVICEDESC$ $EVENT_TXT$ '
-|                                    '- Agent needs to be updated',
-|       'loc': (5, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (6, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (7, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                 'insert_html_section': '<H3>This is a message about your manual '
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (8, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (9, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (10, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (11, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (12, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (13, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (14, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (15, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (16, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (17, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (18, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (19, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (20, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (21, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (22, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (23, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (24, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (25, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (26, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (27, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (28, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (29, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|                                        'backup.</H3>\n'
-|                                        '\n'},
-|       'loc': (30, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (31, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (32, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (33, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (34, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (35, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (36, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (37, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (38, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (39, 'notify_plugin', 1),
-|                              'abstime',
-|                              'longoutput',
-|                              'ack_author',
-|                              'ack_comment',
-|                              'perfdata',
-|                              'graph'],
-|       'loc': (40, 'notify_plugin', 1),
-|      {'input': {'from': 'it@xxx.yyy.privat'},
-|       'loc': (41, 'notify_plugin', 1),
-|  31/32 Update core config...
-| Generating configuration for core (type nagios)...
-| Precompiling host checks...OK
-|  32/32 Migrate legacy frozen aggregations....
-| No frozen aggregations found.
-| Done (with errors)
Here the problematic config file “etc/check_mk/conf.d/wato/notifications.mk”
notification_rules += [{'allow_disable': True,
  'bulk': ('always',
           {'count': 1000,
            'groupby': ['host'],
            'groupby_custom': [],
            'interval': 300}),
  'comment': '',
  'contact_all': False,
  'contact_all_with_email': False,
  'contact_object': False,
  'contact_users': ['ge1001'],
  'description': 'Notifications for servers w/o qosvm2 + loginr',
  'disabled': False,
  'docu_url': '',
  'match_exclude_hosts': ['qosvm2.vm.yyy-zzz.de',
                          'login.xxx.yyy-zzz.de',
                          'vm-qos-backup'],
  'match_host_event': ['rd', 'ru', 'dr', 'ur', 'f'],
  'match_hosttags': ['server'],
  'match_service_event': ['cr', '?w', '?c'],
  'match_services': ['SMART',
                     'DSM_Backup',
                     'Mount',
                     'Filesystem',
                     'ssh',
                     'CUPS',
                     'zpool status',
                     'RAID',
                     'MD Softraid',
                     'Check_MK',
                     'Backups_on_.*',
                     'IPMI Sensor Summary'],
  'notify_plugin': ('mail',
                                  'address',
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                     'url_prefix': {'manual': 'http://xxx.yyy.privat.privat/it/check_mk/'}}),
  'rule_id': 'fb808cb3-14e7-4201-b9d5-fda0ee1fa60a'},
  'bulk': ('always',
           {'count': 1000,
            'groupby': ['host', 'service'],
            'interval': 60}),
  'comment': '',
  'description': 'Notifications for clients windows',
  'disabled': False,
  'docu_url': '',
  'match_exclude_services': ['System Updates'],
  'match_hosttags': ['windows', 'client'],
  'match_service_event': ['?r', '?w', '?c', '?u'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'e0bdad4a-2858-4ecb-96f3-0c7dad9d2695'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 60}),
  'comment': '',
  'description': 'Notifications for fs',
  'disabled': False,
  'docu_url': '',
  'match_exclude_services': ['CPU utilization', 'APT Updates'],
  'match_hosts': ['fs'],
  'match_hosttags': [],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '99f9c053-56cb-44ad-9537-9a8bb858c518'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 60}),
  'comment': '',
  'contact_groups': ['IT'],
  'description': 'Notifications for clients except windows',
  'disabled': False,
  'docu_url': '',
  'match_host_event': [],
  'match_hosttags': ['!windows', 'client'],
  'match_service_event': ['cr', '?c'],
  'match_services': ['^SMART',
                     'DSM',
                     'Mount',
                     'Filesystem',
                     'Process',
                     'CUPS',
                     'Log System',
                     'Log Application',
                     'MD Softraid',
                     'RAID',
                     'DEFUNCT',
                     'ssh'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'c5280efd-4e49-441b-9c7e-8e512f1408ae'},
  'comment': '',
  'description': 'File /etc/cron.hourly/sensorcronjob',
  'disabled': False,
  'docu_url': 'https://wiki.yyy-zzz.de/it-physik/doku.php?id=internal:hwg_ste2#sicherheit_dass_die_temperatur_ueberwacht_wird',
  'match_service_event': ['?r', '?w', '?c', '?u', 'af'],
  'match_services': ['File /etc/cron.hourly/sensorcronjob'],
                                  'abstime',
                                  'longoutput',
                                  'perfdata'],
                                            'href="https://wiki.yyy-zzz.de/it-physik/doku.php?id=internal:hwg_ste2#sicherheit_dass_die_temperatur_ueberwacht_wird">HIER</a> '
                                            'findest du '
                     'service_subject': 'Something has happened to cronjob '
                                        'script that oversees whether '
                                        'serverroom temperature is being '
                                        'monitored'}),
  'rule_id': '3631a255-5d1b-4e84-97ec-e296ace2c13b'},
  'bulk': ('always',
           {'count': 1000,
            'groupby': ['service'],
            'interval': 60}),
  'comment': '',
  'description': 'Warn about outdated agent',
  'disabled': False,
  'docu_url': '',
  'match_plugin_output': '.*unexpected agent version.*',
  'match_services': ['Check_MK'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                     'service_subject': 'Check_MK: $HOSTNAME$/$SERVICEDESC$ '
                                        '$EVENT_TXT$ - Agent needs to be '
                                        'updated',
  'rule_id': '4cebb39a-4cf9-46d2-876f-775e8c98a397'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
  'comment': 'NFS-Fehlermeldungen sind für Server und Clients wichtig. \n'
             '\n'
             'Allerdings führt automount immer wieder automatisch umount und '
             'mount aus. Bei LTSP-Clients passiert das dann immer wieder. '
             'Meldungen von den LTSP-Clients sind aber nicht wichtig, weil der '
             'Vorgang normal, ja sogar gewünscht ist.\n',
  'description': 'NFS notifications but not bmd',
  'disabled': False,
  'docu_url': '',
  'match_hosttags': ['!Stock'],
  'match_services': ['NFS'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '013088cd-b593-4575-a88b-15a291e4bad8'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
             '\n'
  'contact_groups': ['Linux'],
  'description': 'NFS notifications',
  'disabled': False,
  'docu_url': '',
  'match_hosttags': ['!CIP'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'b12ab55b-7063-44f4-ae2b-19a15c5fc16c'},
  'comment': '',
  'contact_emails': [],
  'contact_groups': ['OSX'],
  'description': 'Notification for OS X SMB backups qos001',
  'disabled': True,
  'docu_url': '',
  'match_escalation_throttle': (1, 3),
  'match_service_event': ['?r', '?w', '?c', 'x'],
  'match_services': ['SmbBackup_qos001'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                     'insert_html_section': '<H3>This is a message about your '
                                            'manual backup.</H3>\n'
                                            '\n'}),
  'rule_id': '3e6acf7e-d912-4401-9475-89e8a6457c05'},
  'comment': '',
  'contact_emails': ['firstname.lastname@xxx.yyy-zzz.de'],
  'description': 'Notification for OS X SMB backups qos002',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos002'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '49270d3e-e0bb-4532-80b0-1c7c03b64226'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos003',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos003'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': 'b8b68acb-a0b1-442e-820d-f928946b6ec0'},
  'comment': '',
  'contact_emails': ['firstname.lastname@mars.yyy-zzz.de'],
  'description': 'Notification for OS X SMB backups qos004',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos004'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '39d696c1-3e44-4431-9e6e-e1a150fb0f27'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos005',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos005'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': 'adde7db1-2ebf-4286-b284-7b76bc4e83c2'},
  'comment': '',
  'contact_emails': ['firstname.lastname@email.yyy-zzz.de'],
  'description': 'Notification for OS X SMB backups qos006',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos006'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '23f675b2-5d88-4979-ba88-df4d36635b4b'},
  'comment': '',
  'contact_emails': ['firstname.lastname@students.yyy-zzz.de'],
  'description': 'Notification for OS X SMB backups qos007',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos007'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '8f576c81-a578-4a07-87b6-25b14bf4b479'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos008',
  'disabled': True,
  'docu_url': '',
  'match_services': ['SmbBackup_qos008'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '61817a29-3e54-4440-8a36-5ccc657b7317'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos009',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos009'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': 'fce2f88d-3b7d-44cd-b146-f210c24a30ae'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos010',
  'disabled': True,
  'docu_url': '',
  'match_services': ['SmbBackup_qos010'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '2d42dbe9-d3bd-4297-baf8-91cf0a6e5b14'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos012',
  'disabled': True,
  'docu_url': '',
  'match_services': ['SmbBackup_qos012'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '3d75b0a1-1e86-49a1-b389-fcea56b647ec'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos013',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos013'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '5e6d3094-ef97-46bc-8802-999ef126485b'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos014',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos014'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '7224cc47-d94b-466f-813c-bca4e6adb204'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos015',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos015'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '830f8e7d-a80e-4b8e-8f36-24568e5ae0ee'},
  'comment': '',
  'contact_emails': ['firstname.lastname@uranus.yyy-zzz.de'],
  'description': 'Notification for OS X SMB backups qos016',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos016'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': 'd23a7a19-d7cd-48ac-ae51-aa239e494d16'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos017',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos017'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '4d41c175-873f-4ab1-988c-03eea0c7148b'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos018',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos018'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '46694873-5230-43b9-8085-925e84688a91'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos019',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos019'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '995ec755-9195-40ec-9748-9827caf07bd5'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos021',
  'disabled': False,
  'docu_url': '',
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '03e857e4-dbaf-4976-9d5a-43219d4d3e8d'},
  'comment': '',
  'contact_emails': ['firstname.lastname@posteo.de'],
  'description': 'Notification for OS X SMB backups qos022',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos022'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '219a2564-9893-4329-9254-4e1b35f03066'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos023',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos023'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': 'adea12ef-3f5f-465b-a381-a31717536c15'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos025',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos025'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '9a6c10df-f398-43b7-97b7-16a7c7f2b941'},
  'comment': '',
  'description': 'Notification for OS X SMB backups qos',
  'disabled': False,
  'docu_url': '',
  'match_services': ['SmbBackup_qos-33'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
                                            '\n'}),
  'rule_id': '67a34569-3e5e-42e7-a493-2d0d4c6b4c09'},
  'comment': 'Critical if there is a security update available. Warning if '
             'there are other updates avaliable\n',
  'description': 'Notification for OS X updates',
  'disabled': False,
  'docu_url': '',
  'match_escalation': (1, 999999),
  'match_hosttags': ['MacOS'],
  'match_service_event': ['rc', 'wr', 'wc', 'cr', 'cw'],
  'match_services': ['OSX_Updates'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'a8743d62-1cc2-4ad1-9b7d-20b700055143'},
  'comment': 'Send an alert if the STE 2 temperature fails for some reason on '
             'check_mk server.\n'
             '\n'
             'This notification needs to be on host ltsp-master because '
             'check-mk is an alias for ltsp-master.\n',
  'description': 'Temperature sensor check disappeared on check_mk server!',
  'disabled': False,
  'docu_url': '',
  'match_hosts': ['ltspmaster'],
  'match_service_event': ['?u', 'af'],
  'match_services': ['Server_Room_Sensor'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'cdda62e4-1242-41bd-9022-19149b2257fb'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 60}),
  'comment': '\n',
  'contact_emails': ['firstname.lastname@xxx.yyy-zzz.de',
  'description': 'Service notification for server room temperature sensors',
  'disabled': False,
  'docu_url': '',
  'match_exclude_hosts': ['acpower02'],
  'match_hosttags': ['sensor'],
  'match_service_event': ['?r', '?w', '?c', '?u', 'x'],
  'match_services': ['Temperature'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '41bedd72-1fe8-45c3-a0a0-ea2445da5658'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
  'comment': '',
  'description': 'Host notifications for temperature sensor in server room',
  'disabled': False,
  'docu_url': '',
  'match_host_event': ['?r', '?d', '?u'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '7b0af7de-2b89-45df-ad98-f678ed99710e'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 60}),
  'comment': '18.08.2019 - The standard temperature notifications were '
             'flooding the inboxes.\n',
  'description': 'Notification for server temperatures',
  'disabled': False,
  'docu_url': '',
  'match_service_event': ['wr', 'cr', '?c'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'a09e0c65-4815-498c-b104-ea2723c02a65'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
  'comment': '',
  'description': 'Notifications for virtual hosts',
  'disabled': False,
  'docu_url': '',
  'match_hosttags': ['virtual'],
  'match_services': ['Filesystem', 'OMD', 'Datastores'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '8680d285-9e51-4712-bb63-35e86f7adc68'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
  'comment': '',
  'description': 'Notifications for login or condor servers',
  'disabled': False,
  'docu_url': '',
  'match_hosttags': ['login_condor'],
  'match_services': ['^SMART', 'Process ssh', 'RAID', 'Process condor'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '1ca9f05f-58d2-4f3a-b29b-0ed4c2934129'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
  'comment': '',
  'description': 'Notifications for compute nodes',
  'disabled': False,
  'docu_url': '',
  'match_hosttags': ['c_node'],
  'match_services': ['^SMART', 'Process ssh', 'RAID'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '18ae5762-94a9-4f02-b871-8ecda11fec96'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 1800}),
  'comment': '',
  'description': 'Notifications for print servers',
  'disabled': False,
  'docu_url': '',
  'match_hosttags': ['print'],
  'match_services': ['^SMART', 'Process cups', 'ssh'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': 'f9d35fcb-e04c-42fd-9041-e8e1a9824c5e'},
  'bulk': ('always',
           {'count': 1000,
            'interval': 300}),
  'comment': '',
  'contact_users': ['mb1591', 'ph1046'],
  'description': 'Notifications for servers',
  'disabled': False,
  'docu_url': '',
                     'DSM_Backup',
                     'Mount',
                     'Filesystem',
                     'ssh',
                     'CUPS',
                     'zpool status',
                     'RAID',
                     'MD Softraid',
                     'Check_MK',
                     'Backups_on_.*',
                     'IPMI Sensor Summary',
                     'Iptables'],
                                  'abstime',
                                  'longoutput',
                                  'ack_author',
                                  'ack_comment',
                                  'perfdata',
                                  'graph'],
  'rule_id': '3f68e132-47b6-43db-8867-845df8589eea'},
  'comment': '',
  'contact_object': True,
  'description': 'Notify all contacts of a host/service via HTML email',
  'disabled': True,
  'docu_url': '',
  'notify_plugin': ('mail', {'from': 'it@xxx.yyy.privat'}),
  'rule_id': '962c2ba2-f065-4d0c-9872-dcb19777c600'}]
Does anyone have an idee where the problem is?
Hi @mbeh, I have seen this issue before: You want to stop the site, backup the configuration file, then modify it to make sure, the from parameter looks like below:
{'from': {'address': 'foo@bar.example', 'display_name': 'Foo'}
Then retry the update.
Hallo Robin,
das setzen eines “Display Name” über die Checkmk Weboberfläche hat das Problem behoben. Vielen Dank für den Hinweis.
Viele Grüße,
Markus
Jein. Der “Display Name” ist egal, aber durch das erneute Abspeichern der Regel wurde das Format korrigiert.
So oder so freut es mich aber, dass du eine Lösung gefunden hast!
Having the same issue here, even the most simple email notification rule like this:
notification_rules += [{‘description’: ‘testnotification’, ‘comment’: ‘’, ‘docu_url’: ‘’, ‘disabled’: False, ‘allow_disable’: True, ‘contact_object’: False, ‘contact_all’: False, ‘contact_all_with_email’: False, ‘contact_emails’: [‘test@test.com’], ‘rule_id’: ‘4e97483e-69f5-4d2b-a9fa-7f6132006994’, ‘notify_plugin’: (‘mail’, {})}]
ends up in the following error when trying to upgrade a 2.3.0p34.cee to 2.4.0p7.cee (tried also older version of 2.4)
etc/check_mk/conf.d/wato/notifications.mk… Failed
1 config error
{‘input’: {},
‘loc’: (0, ‘notify_plugin’, 1),
‘msg’: ‘Input should be a valid string’,
‘type’: ‘string_type’,
‘url’: ‘Redirecting...’}
what is missing here in my 2.3 notifications? what do I have to do to make them updateable?
Thanks!
Christian
this rule works fine for me if i test in 2.3.0p34 and update to 2.4.0p7 ?!
