Problem with Postgresql Plugin
CMK version:2.1.0p8
OS version:Ubuntu 22.04
Error message: Parsing of section postgres_query_duration failed
**Output of “cmk --debug -vvn hostname”:
OMD[checkmk]:~$ cmk --debug -vvn PostgreSQL01
Checkmk version 2.1.0p8
Trying to acquire lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
Got lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Got lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Released lock on /omd/sites/checkmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
Released lock on /omd/sites/checkmk/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7fa706da2760]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(PostgreSQL01, base_path=/omd/sites/checkmk/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 121 sec, allowed is 0 sec)
Connecting via TCP to PostgreSQL01.drag0n141.ext:6556 (30.0s timeout)
Reading data from agent
Write data to cache file /omd/sites/checkmk/tmp/check_mk/cache/PostgreSQL01
Trying to acquire lock on /omd/sites/checkmk/tmp/check_mk/cache/PostgreSQL01
Got lock on /omd/sites/checkmk/tmp/check_mk/cache/PostgreSQL01
Releasing lock on /omd/sites/checkmk/tmp/check_mk/cache/PostgreSQL01
Released lock on /omd/sites/checkmk/tmp/check_mk/cache/PostgreSQL01
Closing TCP connection to PostgreSQL01.drag0n141.ext:6556
[cpu_tracking] Stop [7fa706da2760 - Snapshot(process=posix.times_result(user=0.0, system=0.009999999999999995, children_user=0.0, children_system=0.0, elapsed=1.75))]
[cpu_tracking] Start [7fa706da2fa0]
[PiggybackFetcher] Fetch with cache settings: NoCache(PostgreSQL01, base_path=/omd/sites/checkmk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
Piggyback file '/omd/sites/checkmk/tmp/check_mk/piggyback/PostgreSQL01/Proxmox03': Successfully processed from source 'Proxmox03'
No piggyback files for 'PostgreSQL01.drag0n141.ext'. Skip processing.
[cpu_tracking] Stop [7fa706da2fa0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<lxc_container_cpu_cgroupv2>>> / Transition HostSectionParser -> HostSectionParser
<<<lnx_bonding:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<fail2ban>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_instances>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_sessions>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_stat_database:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_locks:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_query_duration:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_connections:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_stats:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_version:sep(1)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_conn_time>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_bloat:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<sshd_config>>> / Transition HostSectionParser -> HostSectionParser
<<<apt:cached(1658339041,7200):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
  -> Add sections: ['apt', 'check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'df', 'diskstat', 'fail2ban', 'job', 'labels', 'lnx_bonding', 'lnx_if', 'local', 'lxc_container_cpu_cgroupv2', 'md', 'mem', 'mounts', 'nfsmounts', 'postfix_mailq', 'postfix_mailq_status', 'postgres_bloat', 'postgres_conn_time', 'postgres_connections', 'postgres_instances', 'postgres_locks', 'postgres_query_duration', 'postgres_sessions', 'postgres_stat_database', 'postgres_stats', 'postgres_version', 'ps_lnx', 'sshd_config', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest']
<<<proxmox_ve_vm_info:cached(1658342518,90):sep(0)>>> / Transition NOOPParser -> HostSectionParser
<<<proxmox_ve_disk_usage:cached(1658342518,90):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<proxmox_ve_mem_usage:cached(1658342518,90):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<proxmox_ve_vm_backup_status:cached(1658342518,90):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<proxmox_ve_vm_snapshot_age:cached(1658342518,90):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
  -> Add sections: ['labels', 'proxmox_ve_disk_usage', 'proxmox_ve_mem_usage', 'proxmox_ve_vm_backup_status', 'proxmox_ve_vm_info', 'proxmox_ve_vm_snapshot_age']
Received no piggyback data
[cpu_tracking] Start [7fa706d771f0]
value store: synchronizing
Trying to acquire lock on /omd/sites/checkmk/tmp/check_mk/counters/PostgreSQL01
Got lock on /omd/sites/checkmk/tmp/check_mk/counters/PostgreSQL01
Releasing lock on /omd/sites/checkmk/tmp/check_mk/counters/PostgreSQL01
Released lock on /omd/sites/checkmk/tmp/check_mk/counters/PostgreSQL01
APT Updates          12 normal updates, 20 security updates (libssl3, python3.10, libpython3.10-stdlib, python3.10-minimal, libpython3.10-minimal, gpg-wks-client, dirmngr, gnupg-utils, gpg-wks-server, gpg-agent, gpg, gpgconf, gnupg-l10n, gnupg, gpgsm, gpgv, openssl, libfreetype6, libharfbuzz0b, python3-jwt)
Check_MK Agent       Version: 2.1.0p8, OS: linux, TLS is not activated on monitored host (see details), Agent plugins: 5, Local checks: 0
Disk IO SUMMARY      Read: 761 kB/s, Write: 9.86 MB/s, Latency: 694 microseconds
Filesystem /         23.32% used (2.27 of 9.75 GB, warn/crit at 83.65%/89.10%), trend: -93.21 kB / 24 hours
Interface 2          [eth0], (up), MAC: F2:B3:F1:41:A7:3A, Speed: 10 GBit/s, In: 4.15 kB/s (<0.01%), Out: 12.3 kB/s (<0.01%)
Jail sshd            OK - sshd active - 0 failed (0 total), 0 banned (0 total)
MD Softraid md0      Status: active, Spare: 0, Failed: 0, Active: 2, Status: 2/2, UU
MD Softraid md1      Status: active, Spare: 0, Failed: 0, Active: 2, Status: 2/2, UU
Memory               Total virtual memory: 8.18% - 167.53 MB of 2.00 GB, 7 additional details available
Mount options of /   Mount options exactly as expected
Postfix Queue        Deferred queue length: 0, Active queue length: 0
Postfix status       Status: the Postfix mail system is running, PID: 467
PostgreSQL ANALYZE MAIN/atuin_db 5 tables were never analyzed: _sqlx_migrations / sessions / total_history_count_user (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/authentik_db Table: authentik_events_event, Not analyzed for: 21 days 9 hours, 83 tables were never analyzed: authentik_core_user_groups / authentik_core_provider_property_mappings / authentik_crypto_certificatekeypair (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/headscale_db Table: machines, Not analyzed for: 6 seconds, 4 tables were never analyzed: namespaces / pre_auth_keys / api_keys (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/helpy_db No never checked tables
PostgreSQL ANALYZE MAIN/joplin_db Table: changes, Not analyzed for: 21 days 9 hours, 14 tables were never analyzed: shares / share_users / storages (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/matrix_db Table: applied_schema_deltas, Not analyzed for: 21 days 9 hours, 135 tables were never analyzed: dehydrated_devices / deleted_pushers / device_federation_inbox (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/netbox_db Table: auth_permission, Not analyzed for: 21 days 9 hours, 127 tables were never analyzed: circuits_provider / circuits_circuit / circuits_circuittermination (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/opentogethertube_db No never checked tables
PostgreSQL ANALYZE MAIN/paperless_db Table: auth_permission, Not analyzed for: 21 days 9 hours, 17 tables were never analyzed: auth_user_groups / auth_user_user_permissions / auth_user (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/postgres No never checked tables
PostgreSQL ANALYZE MAIN/rallly_db No never checked tables
PostgreSQL ANALYZE MAIN/recipes_db Table: auth_permission, Not analyzed for: 21 days 9 hours, 73 tables were never analyzed: auth_user_groups / auth_group / auth_user_user_permissions (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL ANALYZE MAIN/taskcafe_db Table: task, Not analyzed for: 21 days 9 hours, 25 tables were never analyzed: task_activity_type / system_options / project_member_invited (first 3 shown), Never analyzed tables for: 2 hours 39 minutes
PostgreSQL Bloat MAIN/atuin_db Maximum table bloat at pg_class: 0.15%, Maximum wasted tablespace at pg_class: 16.00 kB, Maximum index bloat at users: 1.0%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 96.00 kB, Summary of top 10 wasted indexspace: 152.00 kB
PostgreSQL Bloat MAIN/authentik_db Maximum table bloat at authentik_events_event: 0.05%, Maximum wasted tablespace at authentik_events_event: 48.00 kB, Maximum index bloat at authentik_sources_ldap_ldapsource: 1.0%, Maximum wasted indexspace at pg_depend: 88.00 kB, Summary of top 10 wasted tablespace: 264.00 kB, Summary of top 10 wasted indexspace: 152.00 kB
PostgreSQL Bloat MAIN/headscale_db Maximum table bloat at machines: 0.95%, Maximum wasted tablespace at machines: 160.00 kB, Maximum index bloat at pre_auth_keys: 1.0%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 256.00 kB, Summary of top 10 wasted indexspace: 136.00 kB
PostgreSQL Bloat MAIN/helpy_db Maximum table bloat at pg_class_oid_index: 1.0%, Maximum wasted tablespace at pg_class: 16.00 kB, Maximum index bloat at pg_depend: 0.24%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 72.00 kB, Summary of top 10 wasted indexspace: 104.00 kB
PostgreSQL Bloat MAIN/joplin_db Maximum table bloat at files: 0.05%, Maximum wasted tablespace at items: 192.00 kB, Maximum index bloat at items: 0%, Maximum wasted indexspace at items: 0.00 B, Summary of top 10 wasted tablespace: 1.86 MB, Summary of top 10 wasted indexspace: 0.00 B
PostgreSQL Bloat MAIN/matrix_db Maximum table bloat at event_json: 0.07%, Maximum wasted tablespace at event_json: 136.00 kB, Maximum index bloat at pushers: 1.0%, Maximum wasted indexspace at pushers: 8.00 kB, Summary of top 10 wasted tablespace: 296.00 kB, Summary of top 10 wasted indexspace: 72.00 kB
PostgreSQL Bloat MAIN/netbox_db Maximum table bloat at pg_depend: 0%, Maximum wasted tablespace at dcim_powerfeed: 40.00 kB, Maximum index bloat at dcim_powerfeed: 1.0%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 344.00 kB, Summary of top 10 wasted indexspace: 176.00 kB
PostgreSQL Bloat MAIN/opentogethertube_db Maximum table bloat at pg_class_oid_index: 1.0%, Maximum wasted tablespace at pg_class: 16.00 kB, Maximum index bloat at pg_depend: 0.24%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 72.00 kB, Summary of top 10 wasted indexspace: 104.00 kB
PostgreSQL Bloat MAIN/paperless_db Maximum table bloat at documents_document: 0.05%, Maximum wasted tablespace at documents_document: 32.00 kB, Maximum index bloat at pg_depend: 0.24%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 288.00 kB, Summary of top 10 wasted indexspace: 104.00 kB
PostgreSQL Bloat MAIN/postgres Maximum table bloat at pg_class_oid_index: 1.0%, Maximum wasted tablespace at pg_class: 16.00 kB, Maximum index bloat at pg_depend: 0.24%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 72.00 kB, Summary of top 10 wasted indexspace: 104.00 kB
PostgreSQL Bloat MAIN/rallly_db Maximum table bloat at pg_class_oid_index: 1.0%, Maximum wasted tablespace at pg_class: 16.00 kB, Maximum index bloat at pg_depend: 0.24%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 72.00 kB, Summary of top 10 wasted indexspace: 104.00 kB
PostgreSQL Bloat MAIN/recipes_db Maximum table bloat at cookbook_shoppinglistentry: 0%, Maximum wasted tablespace at cookbook_shoppinglistentry: 24.00 kB, Maximum index bloat at cookbook_shoppinglistentry: 1.0%, Maximum wasted indexspace at cookbook_shoppinglistentry: 8.00 kB, Summary of top 10 wasted tablespace: 240.00 kB, Summary of top 10 wasted indexspace: 80.00 kB
PostgreSQL Bloat MAIN/taskcafe_db Maximum table bloat at pg_depend: 0%, Maximum wasted tablespace at notification_object: 8.00 kB, Maximum index bloat at notification_object: 1.0%, Maximum wasted indexspace at pg_depend: 104.00 kB, Summary of top 10 wasted tablespace: 72.00 kB, Summary of top 10 wasted indexspace: 176.00 kB
PostgreSQL Connection Time MAIN 0.036 seconds
PostgreSQL Connections MAIN/atuin_db No active connections, No idle connections
PostgreSQL Connections MAIN/authentik_db Used active connections: 0, Used active percentage: 0%, Used idle connections: 2, Used idle percentage: 2.0%
PostgreSQL Connections MAIN/headscale_db Used active connections: 0, Used active percentage: 0%, Used idle connections: 2, Used idle percentage: 2.0%
PostgreSQL Connections MAIN/helpy_db No active connections, No idle connections
PostgreSQL Connections MAIN/joplin_db Used active connections: 0, Used active percentage: 0%, Used idle connections: 1, Used idle percentage: 1.0%
PostgreSQL Connections MAIN/matrix_db No active connections, No idle connections
PostgreSQL Connections MAIN/netbox_db No active connections, No idle connections
PostgreSQL Connections MAIN/opentogethertube_db No active connections, No idle connections
PostgreSQL Connections MAIN/paperless_db Used active connections: 0, Used active percentage: 0%, Used idle connections: 3, Used idle percentage: 3.0%
PostgreSQL Connections MAIN/postgres Used active connections: 1, Used active percentage: 1.0%, Used idle connections: 0, Used idle percentage: 0%
PostgreSQL Connections MAIN/rallly_db No active connections, No idle connections
PostgreSQL Connections MAIN/recipes_db Used active connections: 0, Used active percentage: 0%, Used idle connections: 1, Used idle percentage: 1.0%
PostgreSQL Connections MAIN/taskcafe_db No active connections, No idle connections
PostgreSQL DB MAIN/atuin_db Size Size is 8.66 MB
PostgreSQL DB MAIN/atuin_db Statistics Blocks Read: 0.00/s, Fetches: 25.27/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/authentik_db Size Size is 16.24 MB
PostgreSQL DB MAIN/authentik_db Statistics Blocks Read: 0.00/s, Fetches: 246.75/s, Commits: 2.89/s, Deletes: 0.00/s, Updates: 0.03/s, Inserts: 0.00/s
PostgreSQL DB MAIN/headscale_db Size Size is 8.92 MB
PostgreSQL DB MAIN/headscale_db Statistics Blocks Read: 0.00/s, Fetches: 56.77/s, Commits: 4.73/s, Deletes: 0.00/s, Updates: 0.57/s, Inserts: 0.00/s
PostgreSQL DB MAIN/helpy_db Size Size is 8.37 MB
PostgreSQL DB MAIN/helpy_db Statistics Blocks Read: 0.00/s, Fetches: 25.13/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/joplin_db Size Size is 468.77 MB
PostgreSQL DB MAIN/joplin_db Statistics Blocks Read: 0.00/s, Fetches: 29.06/s, Commits: 0.28/s, Deletes: 0.00/s, Updates: 0.02/s, Inserts: 0.00/s
PostgreSQL DB MAIN/matrix_db Size Size is 22.93 MB
PostgreSQL DB MAIN/matrix_db Statistics Blocks Read: 0.00/s, Fetches: 89.45/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/netbox_db Size Size is 21.38 MB
PostgreSQL DB MAIN/netbox_db Statistics Blocks Read: 0.00/s, Fetches: 91.22/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/opentogethertube_db Size Size is 8.37 MB
PostgreSQL DB MAIN/opentogethertube_db Statistics Blocks Read: 0.00/s, Fetches: 25.13/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/paperless_db Size Size is 12.69 MB
PostgreSQL DB MAIN/paperless_db Statistics Blocks Read: 0.00/s, Fetches: 38.17/s, Commits: 0.19/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/postgres Size Size is 8.35 MB
PostgreSQL DB MAIN/postgres Statistics Blocks Read: 0.00/s, Fetches: 33.70/s, Commits: 0.21/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/rallly_db Size Size is 8.35 MB
PostgreSQL DB MAIN/rallly_db Statistics Blocks Read: 0.00/s, Fetches: 25.13/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/recipes_db Size Size is 14.36 MB
PostgreSQL DB MAIN/recipes_db Statistics Blocks Read: 0.00/s, Fetches: 31.50/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/taskcafe_db Size Size is 9.47 MB
PostgreSQL DB MAIN/taskcafe_db Statistics Blocks Read: 0.00/s, Fetches: 28.09/s, Commits: 0.06/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/template1 Size Size is 8.35 MB
PostgreSQL DB MAIN/template1 Statistics Blocks Read: 0.00/s, Fetches: 0.23/s, Commits: 0.03/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL Daemon Sessions MAIN Total: 1, Running: 1
PostgreSQL Instance MAIN Status: running with PID 15696
PostgreSQL Locks MAIN/atuin_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/authentik_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/headscale_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/helpy_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/joplin_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/matrix_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/netbox_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/opentogethertube_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/paperless_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/postgres Access Share Locks 1, Exclusive Locks 0
PostgreSQL Locks MAIN/rallly_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/recipes_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL Locks MAIN/taskcafe_db Access Share Locks 0, Exclusive Locks 0
PostgreSQL VACUUM MAIN/atuin_db 5 tables were never vacuumed: _sqlx_migrations / sessions / total_history_count_user (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/authentik_db Table: authentik_core_source, Not vacuumed for: 13 days 15 hours, 91 tables were never vacuumed: authentik_core_user_groups / authentik_core_provider_property_mappings / authentik_core_user (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/headscale_db Table: machines, Not vacuumed for: 9 hours 58 minutes, 4 tables were never vacuumed: namespaces / pre_auth_keys / api_keys (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/helpy_db No never checked tables
PostgreSQL VACUUM MAIN/joplin_db Table: changes, Not vacuumed for: 21 days 9 hours, 14 tables were never vacuumed: shares / share_users / storages (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/matrix_db Table: cache_invalidation_stream_by_instance, Not vacuumed for: 21 days 9 hours, 143 tables were never vacuumed: dehydrated_devices / deleted_pushers / destination_rooms (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/netbox_db Table: extras_objectchange, Not vacuumed for: 21 days 9 hours, 134 tables were never vacuumed: circuits_provider / circuits_circuit / circuits_circuittermination (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/opentogethertube_db No never checked tables
PostgreSQL VACUUM MAIN/paperless_db Table: django_q_task, Not vacuumed for: 4 hours 32 minutes, 24 tables were never vacuumed: auth_user_groups / auth_user_user_permissions / auth_user (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/postgres No never checked tables
PostgreSQL VACUUM MAIN/rallly_db No never checked tables
PostgreSQL VACUUM MAIN/recipes_db 79 tables were never vacuumed: auth_user_groups / auth_group / auth_user_user_permissions (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL VACUUM MAIN/taskcafe_db 27 tables were never vacuumed: task_activity_type / system_options / project_member_invited (first 3 shown), Never vacuumed tables for: 2 hours 39 minutes
PostgreSQL Version main PostgreSQL 14.4 (Ubuntu 14.4-1.pgdg22.04+1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, 64-bit
Proxmox VE Disk Usage 18.03% used (1.89 GB of 10.5 GB)
Proxmox VE Memory Usage Usage: 8.19% - 168 MiB of 2.00 GiB
Proxmox VE VM Backup Status Age: 1 day 17 hours, Server local start time: 2022-07-19 03:07:20+02:00, Duration: 39 seconds, Dedup rate: 4.58, Bandwidth: 11.0 MB/s
Proxmox VE VM Info   VM ID: 105, Status: running, Type: lxc, Host: Proxmox03
Proxmox VE VM Snapshot age No snapshot found
SSH daemon configuration Protocol: 2, PermitRootLogin: key-based, PasswordAuthentication: no, PermitEmptyPasswords: no, UsePAM: no, X11Forwarding: no
Systemd Service Summary Total: 99, Disabled: 4, Failed: 1
TCP Connections      Established: 10
Uptime               Up since Jun 29 2022 10:59:07, Uptime: 21 days 9 hours
[cpu_tracking] Stop [7fa706d771f0 - Snapshot(process=posix.times_result(user=0.040000000000000036, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.03999999910593033))]
[agent] Success, [piggyback] Successfully processed from source 'Proxmox03', execution time 1.8 sec | execution_time=1.790 user_time=0.040 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=1.740** (If it is a problem with checks or plugins)
Hi @DrAg0n141 , I have the same Problem here.
CMK Version: Checkmk Enterprise Edition 2.1.0p11
OS version: Ubuntu 20.04 LTS
Error Message: Parsing of section postgres_query_duration failed
Output of cmk --debug --vvn hostname
OMD[mysite]:~$ cmk -vvn --debug brandenburg-api
Checkmk version 2.1.0p11
Trying to acquire lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Got lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Got lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Released lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Released lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f6637e4dfd0]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(brandenburg-api, base_path=/omd/sites/mysite/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 75 sec, allowed is 0 sec)
Connecting via TCP to api2.tmb.pixelpoint.biz:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Write data to cache file /omd/sites/mysite/tmp/check_mk/cache/brandenburg-api
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/cache/brandenburg-api
Got lock on /omd/sites/mysite/tmp/check_mk/cache/brandenburg-api
Releasing lock on /omd/sites/mysite/tmp/check_mk/cache/brandenburg-api
Released lock on /omd/sites/mysite/tmp/check_mk/cache/brandenburg-api
Closing TCP connection to api2.tmb.pixelpoint.biz:6556
[cpu_tracking] Stop [7f6637e4dfd0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.009999999999999953, children_user=0.0, children_system=0.0, elapsed=1.9800000004470348))]
[cpu_tracking] Start [7f6637e4beb0]
[PiggybackFetcher] Fetch with cache settings: NoCache(brandenburg-api, base_path=/omd/sites/mysite/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'brandenburg-api'. Skip processing.
No piggyback files for 'api2.tmb.pixelpoint.biz'. Skip processing.
[cpu_tracking] Stop [7f6637e4beb0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
<<<varnish>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_instance:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_asserts>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_connections>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_locks>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_mem>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_counters>>> / Transition HostSectionParser -> HostSectionParser
<<<mongodb_collections:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<logwatch>>> / Transition HostSectionParser -> HostSectionParser
<<<redis_info:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<check_mk:cached(1663311668,10800)>>> / Transition HostSectionParser -> HostSectionParser
Trying to acquire lock on /omd/sites/mysite/var/check_mk/persisted/brandenburg-api
Got lock on /omd/sites/mysite/var/check_mk/persisted/brandenburg-api
Releasing lock on /omd/sites/mysite/var/check_mk/persisted/brandenburg-api
Released lock on /omd/sites/mysite/var/check_mk/persisted/brandenburg-api
Stored persisted sections: lnx_packages, lnx_distro, lnx_cpuinfo, lnx_uname, lnx_ip_r, lnx_sysctl, lnx_block_devices
Using persisted section SectionName('lnx_packages')
Using persisted section SectionName('lnx_distro')
Using persisted section SectionName('lnx_cpuinfo')
Using persisted section SectionName('lnx_uname')
Using persisted section SectionName('lnx_ip_r')
Using persisted section SectionName('lnx_sysctl')
Using persisted section SectionName('lnx_block_devices')
  -> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'lnx_block_devices', 'lnx_bonding', 'lnx_cpuinfo', 'lnx_distro', 'lnx_if', 'lnx_ip_r', 'lnx_packages', 'lnx_sysctl', 'lnx_uname', 'local', 'logwatch', 'md', 'mem', 'mongodb_asserts', 'mongodb_collections', 'mongodb_connections', 'mongodb_counters', 'mongodb_instance', 'mongodb_locks', 'mongodb_mem', 'mounts', 'nfsmounts', 'postgres_bloat', 'postgres_conn_time', 'postgres_connections', 'postgres_instances', 'postgres_locks', 'postgres_query_duration', 'postgres_sessions', 'postgres_stat_database', 'postgres_stats', 'postgres_version', 'ps_lnx', 'redis_info', 'systemd_units', 'tcp_conn_stats', 'uptime', 'varnish', 'vbox_guest']
  -> Add sections: []
[cpu_tracking] Start [7f6637f62700]
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/counters/brandenburg-api
Got lock on /omd/sites/mysite/tmp/check_mk/counters/brandenburg-api
Releasing lock on /omd/sites/mysite/tmp/check_mk/counters/brandenburg-api
Released lock on /omd/sites/mysite/tmp/check_mk/counters/brandenburg-api
CPU load             15 min load: 3.19, 15 min load per core: 0.32 (10 cores)
CPU utilization      Total CPU: 33.32%
Check_MK Agent       Version: 2.1.0p11, OS: linux, Last update: Sep 14 2022 11:56:23, Agent plugins: 8, Local checks: 9
Filesystem /         86.99% used (694.59 of 798.50 GB), trend: -8.22 GB / 24 hours
Interface 2          [venet0], (up), Speed: 10 GBit/s, In: 28.1 kB/s (<0.01%), Out: 930 kB/s (0.07%)
Job rdiff-backup-etc Latest exit code: 0, Real time: 22 seconds, Job age: 1 day 5 hours
Job rdiff-backup-mongo Latest exit code: 0, Real time: 3 minutes 45 seconds, Job age: 5 hours 34 minutes
Job rdiff-backup-postgres Latest exit code: 0, Real time: 1 minute 21 seconds, Job age: 5 hours 36 minutes
Job rdiff-backup-redis Latest exit code: 0, Real time: 10 minutes 3 seconds, Job age: 1 day 5 hours
Job rdiff-backup-www Latest exit code: 1(!!), Real time: 4 seconds, Job age (currently running): 5 hours 30 minutes
Job rdiff-cleanup-etc Latest exit code: 0, Real time: 4 seconds, Job age: 5 hours 36 minutes
Job rdiff-cleanup-mongo Latest exit code: 0, Real time: 5 seconds, Job age: 5 hours 45 minutes
Job rdiff-cleanup-postgres Latest exit code: 0, Real time: 7 seconds, Job age: 5 hours 45 minutes
Job rdiff-cleanup-redis Latest exit code: 0, Real time: 4 seconds, Job age: 5 hours 36 minutes
Job rdiff-cleanup-www Latest exit code: 0, Real time: 9 minutes 28 seconds, Job age: 5 hours 45 minutes
LetsEncrypt-Certs    All certs valid, Cache generated 1 hour 23 minutes ago, cache interval: 6 hours 0 minutes, elapsed cache lifespan: 23.25%
Log MongoDB startupWarnings 372 WARN messages (Last worst: "2022-09-15T23:00:58.591+0200 I CONTROL [initandlisten] ** WARNING: You are running in OpenVZ which can cause issues on versions of RHEL older than RHEL6.")
Logrotation          Rotation as expected
Memory               Total virtual memory: 38.43% - 12.30 GB of 32.00 GB, 4 additional details available
Memory used MongoDB  Resident usage: 2.07 GB, Virtual usage: 2.45 GB, Mapped usage: 0.00 B
MongoDB Asserts      0.00 Regular Asserts/sec, 0.00 User Asserts/sec, 0.00 Msg Asserts/sec, 0.00 Rollovers Asserts/sec, 0.00 Warning Asserts/sec
MongoDB Connections  Used connections: 2, Used percentage: 0.24%, Rate: 0.025768837235979145/sec
MongoDB Counters Operations Update: 0.00/s, Getmore: 0.00/s, Insert: 0.00/s, Query: 0.00/s, Delete: 0.00/s, Command: 2.28/s
MongoDB Counters Replica Operations Update: 0.00/s, Getmore: 0.00/s, Insert: 0.00/s, Query: 0.00/s, Delete: 0.00/s, Command: 0.00/s
MongoDB Instance     Version: 3.2.17, Pid: 352, Mode: Single Instance
MongoDB Locks        Clients-Writers: 0, Clients-Total: 9, Clients-Readers: 0, Queue-Writers: 0, Queue-Total: 0, Queue-Readers: 0
PostgreSQL ANALYZE MAIN/brandenburg_data_loader_production Table: convention_ratings, Not analyzed for: 7 days 21 hours, No never checked tables
PostgreSQL Bloat MAIN/brandenburg_data_loader_production Maximum table bloat at articles: 0.69%, Maximum wasted tablespace at assets: 23.81 MB, Maximum index bloat at services: 0.97%, Maximum wasted indexspace at services: 13.55 MB, Summary of top 10 wasted tablespace: 133.84 MB, Summary of top 10 wasted indexspace: 24.27 MB
PostgreSQL Bloat MAIN/postgres Maximum table bloat at pg_conversion: 0.33%, Maximum wasted tablespace at pg_description: 16.00 kB, Maximum index bloat at pg_amproc: 0.4%, Maximum wasted indexspace at pg_amproc: 16.00 kB, Summary of top 10 wasted tablespace: 88.00 kB, Summary of top 10 wasted indexspace: 24.00 kB
PostgreSQL Connections MAIN/brandenburg_data_loader_production Used active connections: 1, Used active percentage: 1.0%, Used idle connections: 15, Used idle percentage: 15.0%
PostgreSQL DB MAIN/brandenburg_data_loader_production Size Size is 2.81 GB
PostgreSQL DB MAIN/brandenburg_data_loader_production Statistics Blocks Read: 39288.61/s, Fetches: 23934.45/s, Commits: 181.82/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/postgres Size Size is 5.79 MB
PostgreSQL DB MAIN/postgres Statistics Blocks Read: 3.49/s, Fetches: 39.99/s, Commits: 0.31/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/template1 Size Size is 6.90 MB
PostgreSQL DB MAIN/template1 Statistics Blocks Read: 0.39/s, Fetches: 0.14/s, Commits: 0.03/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL Daemon Sessions MAIN Total: 2, Running: 2
PostgreSQL Instance MAIN Status: running with PID 557
PostgreSQL Locks MAIN/brandenburg_data_loader_production Access Share Locks 4, Exclusive Locks 0
PostgreSQL VACUUM MAIN/brandenburg_data_loader_production Table: offerings, Not vacuumed for: 7 days 22 hours, No never checked tables
PostgreSQL Version main PostgreSQL 9.6.5 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609, 64-bit
Process puma         Processes: 5, virtual: 6.36 GiB, physical: 2.20 GiB, CPU: 6.44%, Running for: 4 minutes 55 seconds
Reboot               OK
Redis 127.0.0.1:6379 Clients Number of client connections: 9, Longest output list: 0, Biggest input buffer: 0, Number of clients pending on a blocking call: 0
Redis 127.0.0.1:6379 Persistence Last RDB save operation: successful (Duration: 40.0 s), Last AOF rewrite operation: successful, Last successful RDB save: 2022-09-16 09:52:31, Number of changes since last dump: 2288
Redis 127.0.0.1:6379 Server Info Mode: Standalone, Up since Thu Sep 15 23:00:58 2022, uptime: 10:55:50, Version: 3.0.6, GCC compiler version: 5.4.0, PID: 495, IP: 127.0.0.1, Port: 6379
Systemd Service Summary Total: 84, Disabled: 2, Failed: 0
Systemd Service nginx Status: active, A high performance web server and a reverse proxy server
Systemd Service redis-server Status: active, Advanced key-value store
Systemd Service solr Status: active, LSB: Controls Apache Solr as a Service
UFW                  running
Uptime               Up since Sep 15 2022 23:00:55, Uptime: 10 hours 55 minutes
+ EXECUTING INVENTORY PLUGINS
 aruba_wlc_aps: skipped (no data)
 check_mk: ok
 check_mk: skipped (no data)
 checkmk_agent_plugins: ok
 checkmk_agent_plugins: skipped (no data)
 docker_node_info: skipped (no data)
 fritz: skipped (no data)
 hp_proliant_da_phydrv: skipped (no data)
 hp_proliant_mem: skipped (no data)
 ibm_mq_channels: skipped (no data)
 ibm_mq_managers: skipped (no data)
 ibm_mq_queues: skipped (no data)
 ipmi_firmware: skipped (no data)
 inv_cisco_vlans: skipped (no data)
 inv_esx_vsphere_hostsystem: skipped (no data)
 inv_if: ok
 inv_if: skipped (no data)
 aix_packages: skipped (no data)
 aix_service_packs: skipped (no data)
 inventory_checkmk: skipped (no data)
 checkpoint_vpn_tunnels: skipped (no data)
 dmidecode: skipped (no data)
 docker_container_labels: skipped (no data)
 docker_container_network: skipped (no data)
 docker_node_images: skipped (no data)
 docker_node_network: skipped (no data)
 inventory_esx_vsphere_clusters: skipped (no data)
 inventory_esx_vsphere_virtual_machines: skipped (no data)
 fortiauthenticator_system: skipped (no data)
 fortigate_ha: skipped (no data)
 fortimail_system: skipped (no data)
 fortisandbox_software: skipped (no data)
 fortisandbox_system: skipped (no data)
 k8s_assigned_pods: skipped (no data)
 k8s_daemon_pod_containers: skipped (no data)
 k8s_endpoint_info: skipped (no data)
 k8s_ingress_infos: skipped (no data)
 k8s_job_container: skipped (no data)
 kube_cluster: skipped (no data)
 kube_daemonset: skipped (no data)
 kube_deployment: skipped (no data)
 kube_namespace: skipped (no data)
 kube_node: skipped (no data)
 kube_pod: skipped (no data)
 kube_statefulset: skipped (no data)
 lnx_block_devices: ok
 lnx_block_devices: skipped (no data)
 lnx_ip_r: ok
 lnx_ip_r: skipped (no data)
 lnx_packages: ok
 lnx_packages: skipped (no data)
 lnx_sysctl: ok
 lnx_sysctl: skipped (no data)
 lnx_video: skipped (no data)
 mobileiron_inventory: ok
 mobileiron_inventory: skipped (no data)
 mssql_clusters: skipped (no data)
 oracle_systemparameter: skipped (no data)
 snmp_extended_info: skipped (no data)
 solaris_addresses: skipped (no data)
 solaris_pkginfo: skipped (no data)
 solaris_psrinfo: skipped (no data)
 solaris_cpus: skipped (no data)
 solaris_prtpicl: skipped (no data)
 solaris_routes: skipped (no data)
 statgrab_net: skipped (no data)
 win_disks: skipped (no data)
 win_exefiles: skipped (no data)
 win_ip_r: skipped (no data)
 win_networkadapter: skipped (no data)
 win_reg_uninstall: skipped (no data)
 win_video: skipped (no data)
 win_wmi_software: skipped (no data)
 win_wmi_updates: skipped (no data)
 juniper_info: skipped (no data)
 k8s_nodes: skipped (no data)
 k8s_pod_container: skipped (no data)
 k8s_roles: skipped (no data)
 lnx_if: ok
 lnx_if: skipped (no data)
 mem: ok
 mem_used: skipped (no data)
 mssql_instance: skipped (no data)
 netapp_api_disk: skipped (no data)
 oracle_dataguard_stats: skipped (no data)
 oracle_instance: skipped (no data)
 oracle_performance: skipped (no data)
 oracle_recovery_area: skipped (no data)
 oracle_tablespaces: skipped (no data)
 perle_chassis_slots: skipped (no data)
 perle_psmu: skipped (no data)
 snmp_info: skipped (no data)
 winperf_if: skipped (no data)
 aix_baselevel: skipped (no data)
 aix_lparstat_inventory: skipped (no data)
 allnet_ip_sensoric: skipped (no data)
 citrix_controller: skipped (no data)
 citrix_state: skipped (no data)
 couchbase_nodes_ports: skipped (no data)
 dell_hw_info: skipped (no data)
 docker_container_node_name: skipped (no data)
 esx_systeminfo: skipped (no data)
 fireeye_sys_status: skipped (no data)
 hp_proliant_systeminfo: skipped (no data)
 infoblox_osinfo: skipped (no data)
 infoblox_systeminfo: skipped (no data)
 k8s_pod_info: skipped (no data)
 k8s_selector: skipped (no data)
 k8s_service_info: skipped (no data)
 lnx_cpuinfo: ok
 lnx_cpuinfo: skipped (no data)
 lnx_distro: ok
 lnx_distro: skipped (no data)
 lnx_uname: ok
 lnx_uname: skipped (no data)
 lparstat_aix: skipped (no data)
 netapp_api_info: skipped (no data)
 perle_chassis: skipped (no data)
 prtconf: skipped (no data)
 snmp_os: skipped (no data)
 snmp_quantum_storage_info: skipped (no data)
 solaris_prtdiag: skipped (no data)
 solaris_uname: skipped (no data)
 suseconnect: skipped (no data)
 win_bios: skipped (no data)
 win_computersystem: skipped (no data)
 win_cpuinfo: skipped (no data)
 win_os: skipped (no data)
 win_system: skipped (no data)
[cpu_tracking] Stop [7f6637f62700 - Snapshot(process=posix.times_result(user=0.10000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.09999999776482582))]
[agent] Success, execution time 2.1 sec | execution_time=2.080 user_time=0.110 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=1.960
Output of mk_postgres.py on the Server:
root@lvps83-169-0-164:/usr/lib/check_mk_agent/plugins# ./mk_postgres.py
ERROR:  Unicode escape values cannot be used for code point values above 007F when the server encoding is not UTF8 at or near "E'[\n\r\u2028"
ZEILE 1: ...start)),0) AS seconds, pid, regexp_replace(query, E'[\n\r\u2...
[[[main]]]
557 /usr/lib/postgresql/9.6/bin/postgres -D /var/lib/postgresql/9.6/main -c config_file=/etc/postgresql/9.6/main/postgresql.conf
[[[main]]]
f 2
t 17
t 0
[[[main]]]
datid;datname;numbackends;xact_commit;xact_rollback;blks_read;blks_hit;tup_returned;tup_fetched;tup_inserted;tup_updated;tup_deleted;datsize
12413;postgres;1;2570323;6470;37160662;82811386;1291949630;35291931;1826;398;1607;6068760
1;template1;0;2433155;874;35721336;52708274;1233373355;16988143;0;7;0;7240216
12412;template0;0;0;0;0;0;0;0;0;0;0;7119364
17272;brandenburg_data_loader_production;18;10951431663;34323;440420062051;4790120272368;13043832916626;5445378681175;56302299;62143746;70505078;3013065240
[[[main]]]
[databases_start]
postgres
[databases_end]
datname;granted;mode
brandenburg_data_loader_production;t;AccessShareLock
postgres;t;AccessShareLock
template1;;
[[[main]]]
[databases_start]
postgres
[databases_end]
[[[main]]]
[databases_start]
postgres
[databases_end]
datname;mc;idle;active
brandenburg_data_loader_production;100;17;1
postgres;100;0;1
[[[main]]]
[databases_start]
postgres
[databases_end]
datname;sname;tname;vtime;atime
postgres;pg_catalog;pg_statistic;1662630363;-1
postgres;pg_catalog;pg_user_mapping;1662630363;-1
postgres;pg_catalog;pg_proc;1662630363;-1
postgres;pg_catalog;pg_attrdef;1662630363;-1
postgres;pg_catalog;pg_constraint;1662630363;-1
postgres;pg_catalog;pg_inherits;1662630363;-1
postgres;pg_catalog;pg_index;1662630363;-1
postgres;pg_catalog;pg_operator;1662630363;-1
postgres;pg_catalog;pg_opfamily;1662630363;-1
postgres;pg_catalog;pg_opclass;1662630363;-1
postgres;pg_catalog;pg_am;1662630363;-1
postgres;pg_catalog;pg_amop;1662630363;-1
postgres;pg_catalog;pg_amproc;1662630363;-1
postgres;pg_catalog;pg_language;1662630363;-1
postgres;pg_catalog;pg_largeobject_metadata;1662630363;-1
postgres;pg_catalog;pg_aggregate;1662630363;-1
postgres;pg_catalog;pg_rewrite;1662630363;-1
postgres;pg_catalog;pg_largeobject;1662630363;-1
postgres;pg_catalog;pg_trigger;1662630363;-1
postgres;pg_catalog;pg_event_trigger;1662630363;-1
postgres;pg_catalog;pg_description;1662630363;-1
postgres;pg_catalog;pg_cast;1662630363;-1
postgres;pg_catalog;pg_enum;1662630363;-1
postgres;pg_catalog;pg_namespace;1662630363;-1
postgres;pg_catalog;pg_conversion;1662630363;-1
postgres;pg_catalog;pg_depend;1662630363;-1
postgres;pg_catalog;pg_ts_config;1662630363;-1
postgres;pg_catalog;pg_ts_config_map;1662630363;-1
postgres;pg_catalog;pg_ts_dict;1662630363;-1
postgres;pg_catalog;pg_ts_parser;1662630363;-1
postgres;pg_catalog;pg_ts_template;1662630363;-1
postgres;pg_catalog;pg_extension;1662630363;-1
postgres;pg_catalog;pg_foreign_data_wrapper;1662630363;-1
postgres;pg_catalog;pg_foreign_server;1662630363;-1
postgres;pg_catalog;pg_foreign_table;1662630363;-1
postgres;pg_catalog;pg_policy;1662630363;-1
postgres;pg_catalog;pg_default_acl;1662630363;-1
postgres;pg_catalog;pg_init_privs;1662630363;-1
postgres;pg_catalog;pg_seclabel;1662630363;-1
postgres;pg_catalog;pg_collation;1662630363;-1
postgres;pg_catalog;pg_range;1662630363;-1
postgres;pg_catalog;pg_transform;1662630363;-1
postgres;pg_catalog;pg_type;1662630675;1662630675
postgres;pg_catalog;pg_attribute;1662630676;1662630676
postgres;pg_catalog;pg_class;1662630676;1662630676
postgres;pg_catalog;pg_authid;1662630799;1662631310
postgres;pg_catalog;pg_database;1662630800;1662631308
postgres;pg_catalog;pg_db_role_setting;1662630800;1662631308
postgres;pg_catalog;pg_tablespace;1662630800;1662631308
postgres;pg_catalog;pg_pltemplate;1662630800;1662631308
postgres;pg_catalog;pg_auth_members;1662630800;1662631308
postgres;pg_catalog;pg_shdescription;1662630800;1662631308
postgres;pg_catalog;pg_replication_origin;1662630800;1662631308
postgres;pg_catalog;pg_shseclabel;1662630800;1662631308
postgres;pg_catalog;pg_shdepend;1662631135;1662631308
brandenburg_data_loader_production;pg_catalog;pg_authid;1662630799;1662631310
brandenburg_data_loader_production;pg_catalog;pg_user_mapping;1662630799;1662631310
brandenburg_data_loader_production;pg_catalog;pg_proc;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_attrdef;1662630800;1662631314
brandenburg_data_loader_production;pg_catalog;pg_constraint;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_inherits;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_index;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_operator;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_opfamily;1662630800;1662631314
brandenburg_data_loader_production;pg_catalog;pg_opclass;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_am;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_amop;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_amproc;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_language;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_largeobject_metadata;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_aggregate;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_rewrite;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_largeobject;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_trigger;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_event_trigger;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_description;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_cast;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_enum;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_namespace;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_conversion;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_depend;1662630800;1662631307
brandenburg_data_loader_production;pg_catalog;pg_database;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_db_role_setting;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_tablespace;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_pltemplate;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_auth_members;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_shdescription;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_ts_config;1662630800;1662631314
brandenburg_data_loader_production;pg_catalog;pg_ts_config_map;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_ts_dict;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_ts_parser;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_ts_template;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_extension;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_foreign_data_wrapper;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_foreign_server;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_foreign_table;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_policy;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_replication_origin;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_default_acl;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_init_privs;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_seclabel;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_shseclabel;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_collation;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_range;1662630800;1662631308
brandenburg_data_loader_production;pg_catalog;pg_transform;1662630800;1662631308
brandenburg_data_loader_production;public;offerings;1662630801;1662631309
brandenburg_data_loader_production;public;convention_ratings;1662630802;1662631309
brandenburg_data_loader_production;public;galleries;1662630802;1662631310
brandenburg_data_loader_production;public;keywords;1662630802;1662631310
brandenburg_data_loader_production;public;package_assets;1662630802;1662631310
brandenburg_data_loader_production;public;location_region_connections;1662630802;1662631310
brandenburg_data_loader_production;public;package_asset_links;1662630802;1662631310
brandenburg_data_loader_production;public;poi_links;1662630802;1662631310
brandenburg_data_loader_production;public;ratings;1662630802;1662631310
brandenburg_data_loader_production;public;spatial_ref_sys;1662630802;1662631310
brandenburg_data_loader_production;public;poi_datasheet_links;1662630802;1662631310
brandenburg_data_loader_production;public;event_assets;1662630802;1663021337
brandenburg_data_loader_production;public;categories;1662630822;1662631311
brandenburg_data_loader_production;public;event_categories;1662630822;1662631311
brandenburg_data_loader_production;public;districts;1662630822;1663281861
brandenburg_data_loader_production;public;ar_internal_metadata;1662630822;1662631313
brandenburg_data_loader_production;public;classification_links;1662630822;1662631313
brandenburg_data_loader_production;public;schema_migrations;1662630822;1662631313
brandenburg_data_loader_production;public;service_connections;1662630822;1662631314
brandenburg_data_loader_production;public;taxonomy_hierarchies;1662630823;1662631314
brandenburg_data_loader_production;public;trips;1662630823;1662631315
brandenburg_data_loader_production;public;taxonomies;1662630823;1662631315
brandenburg_data_loader_production;public;video_links;1662630823;1662631315
brandenburg_data_loader_production;public;logs;1662630956;1662631315
brandenburg_data_loader_production;pg_catalog;pg_type;1662631114;1662631307
brandenburg_data_loader_production;pg_catalog;pg_attribute;1662631115;1662631310
brandenburg_data_loader_production;pg_catalog;pg_class;1662631115;1662631314
brandenburg_data_loader_production;pg_catalog;pg_shdepend;1662631135;1662631308
brandenburg_data_loader_production;public;regions;1662936213;1663281860
brandenburg_data_loader_production;public;ytvideos;1663020314;1663279519
brandenburg_data_loader_production;public;taggings;1663026567;1663282926
brandenburg_data_loader_production;public;products;1663107018;1663020673
brandenburg_data_loader_production;public;event_dates;1663107554;1663193979
brandenburg_data_loader_production;public;assets;1663111881;1663284214
brandenburg_data_loader_production;public;packages;1663207844;1663288642
brandenburg_data_loader_production;public;broshure_thumbnails;1663279400;1663279400
brandenburg_data_loader_production;public;broshures;1663279401;1663279401
brandenburg_data_loader_production;public;segments;1663279699;1663279699
brandenburg_data_loader_production;public;tomas_assets;1663279920;1663280073
brandenburg_data_loader_production;public;event_asset_links;1663280180;1663280239
brandenburg_data_loader_production;public;event_category_links;1663280180;1663280240
brandenburg_data_loader_production;public;events;1663280308;1663280309
brandenburg_data_loader_production;public;classifications;1663281681;1663281860
brandenburg_data_loader_production;public;locations;1663281928;1663281929
brandenburg_data_loader_production;pg_catalog;pg_statistic;1663282162;-1
brandenburg_data_loader_production;public;tours;1663282223;1663282228
brandenburg_data_loader_production;public;offers;1663282282;1663282282
brandenburg_data_loader_production;public;tags;1663282284;1663282284
brandenburg_data_loader_production;public;pois;1663282405;1663283967
brandenburg_data_loader_production;public;services;1663285767;1663285461
brandenburg_data_loader_production;public;availabilities;1663287101;1663288587
brandenburg_data_loader_production;public;package_availabilities;1663288645;1663288705
brandenburg_data_loader_production;public;kijus;1663288822;1663288823
brandenburg_data_loader_production;public;familypasses;1663288826;1663288827
brandenburg_data_loader_production;public;conventions;1663288885;1663288885
brandenburg_data_loader_production;public;datasheets;1663288944;1663288944
brandenburg_data_loader_production;public;articles;1663289727;1663289727
[[[main]]]
[[[main]]]
0.039
[[[main]]]
[databases_start]
postgres
[databases_end]
db;schemaname;tablename;tups;pages;otta;tbloat;wastedpages;wastedbytes;wastedsize;iname;itups;ipages;iotta;ibloat;wastedipages;wastedibytes;wastedisize;totalwastedbytes
postgres;pg_catalog;pg_amproc;546;5;4;0.200;1;8192;8192;pg_amproc_fam_proc_index;546;5;3;0.400;2;16384;16384;24576
postgres;pg_catalog;pg_description;3838;34;32;0.059;2;16384;16384;pg_description_o_c_o_index;3838;17;24;0.000;0;0;0;16384
postgres;pg_catalog;pg_amproc;546;5;4;0.200;1;8192;8192;pg_amproc_oid_index;546;4;3;0.250;1;8192;8192;16384
postgres;pg_catalog;pg_conversion;132;3;2;0.333;1;8192;8192;pg_conversion_default_index;132;2;2;0.000;0;0;0;8192
postgres;pg_catalog;pg_rewrite;117;12;11;0.083;1;8192;8192;pg_rewrite_rel_rulename_index;117;2;11;0.000;0;0;0;8192
postgres;pg_catalog;pg_rewrite;117;12;11;0.083;1;8192;8192;pg_rewrite_oid_index;117;2;11;0.000;0;0;0;8192
postgres;pg_catalog;pg_operator;775;15;14;0.067;1;8192;8192;pg_operator_oprname_l_r_n_index;775;5;12;0.000;0;0;0;8192
postgres;pg_catalog;pg_operator;775;15;14;0.067;1;8192;8192;pg_operator_oid_index;775;5;12;0.000;0;0;0;8192
postgres;pg_catalog;pg_conversion;132;3;2;0.333;1;8192;8192;pg_conversion_oid_index;132;2;2;0.000;0;0;0;8192
postgres;pg_catalog;pg_conversion;132;3;2;0.333;1;8192;8192;pg_conversion_name_nsp_index;132;2;2;0.000;0;0;0;8192
brandenburg_data_loader_production;public;assets;82352;14617;11569;0.209;3048;24969216;24969216;index_assets_on_thumbs;82352;10176;11147;0.000;0;0;0;24969216
brandenburg_data_loader_production;public;assets;82352;14617;11569;0.209;3048;24969216;24969216;index_assets_on_data;82352;4706;11147;0.000;0;0;0;24969216
brandenburg_data_loader_production;public;assets;82352;14617;11569;0.209;3048;24969216;24969216;assets_pkey;82352;232;11147;0.000;0;0;0;24969216
brandenburg_data_loader_production;public;pois;32146;5032;4258;0.154;774;6340608;6340608;index_pois_on_data;32146;5131;4099;0.201;1032;8454144;8454144;14794752
brandenburg_data_loader_production;public;services;4584;70;67;0.043;3;24576;24576;index_services_on_data;4584;1786;51;0.971;1735;14213120;14213120;14237696
brandenburg_data_loader_production;public;tomas_assets;32582;6318;4641;0.265;1677;13737984;13737984;index_tomas_assets_on_external_id;32582;685;4480;0.000;0;0;0;13737984
brandenburg_data_loader_production;public;tomas_assets;32582;6318;4641;0.265;1677;13737984;13737984;index_tomas_assets_on_data;32582;1706;4480;0.000;0;0;0;13737984
brandenburg_data_loader_production;public;tomas_assets;32582;6318;4641;0.265;1677;13737984;13737984;index_tomas_assets_on_thumbs;32582;2230;4480;0.000;0;0;0;13737984
brandenburg_data_loader_production;public;tomas_assets;32582;6318;4641;0.265;1677;13737984;13737984;tomas_assets_pkey;32582;158;4480;0.000;0;0;0;13737984
brandenburg_data_loader_production;public;articles;2723;729;226;0.690;503;4120576;4120576;index_articles_on_data;2723;558;219;0.608;339;2777088;2777088;6897664
Did you ever find out what was wrong?
Does anyone know what this error means?
wasn’t fixed I suppose? I have a similar error after updateing to 2.1.0p29 :confused:
Parsing of section postgres_stats failed - please submit a crash report! (Crash-ID: 909c17e5-0aaf-11ee-9f8e-2f0df21f798f)
Josef
Not fixed in 2.1.0p30. Could this have something to do with the version of posgresql beeing used. I’m running
PostgreSQL 9.2.24 on x86_64-redhat-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44), 64-bit
Thor
CMK Version: Checkmk Raw Edition 2.2.0p12
OS version: Debian 10
Not fixed yet in 2.2.0p12.
i guess the assumption from Thor could be correct.
PostgreSQL 9.2.24 is now 6 years old and EOL for a long time.
It’s quite possible that the plugin doesn’t work with such an old version.
There should be more information after “[databases_end]” In the output of the section postgres_query_duration.
At least from the outputs deliverd by Sven and Pixelpoint last year i see that this information is missing.
Could be a user permission problem, but i guess it’s the old version of PostgreSQL.
Maybe Josef and/or Goran can also share which version of PostgreSQL they use.
This would make things more clear.
KR,
Max
Facing it both in 14.9 and 16.1. And some other databases with same version are alright, so I would rule out postgresql version.
after “[databases_end]” there is an empty line with problematic servers (same like with Sven and Pixelpoint)
It can be indeed that there are no active queries, but think mk_postgress should recognize this and place something there
Hey,
same problem with “PostgreSQL 13.14, compiled by Visual C++ build 1914, 64-bit” (Windows)
“Parsing of section postgres_stats failed - please submit a crash report! (Crash-ID: a841bc48-3946-11ef-b40c-5d3248e1cf85”
Checkmk Enterprise Edition 2.2.0p26
Josef
