I have some problems with setting up LDAP synchronization with my OpenLDAP server and checkmk edition RAW in version 1.6.0p20
I relied on the following link for the setup: https://docs.checkmk.com/latest/en/ldap.html
Without the implementation of SSL, it works perfectly.
When I switch to port 636 with SSL enabled, I have a certificate error since it is self-signed, so far everything is normal.
I apply what is indicated in the tutorial and import the self-signed certificate of my ldap server with the following command:
certutil -A -d / etc / openldap / certs -n "OpenLDAP Certificat" -t CT ,, -a -i /etc/ssl/certs/ldapserver-cert.pem
Then I restart the httpd service and try again but unfortunately still the same result.
I don’t think I made a mistake though, do you have any ideas?
Best regards
