CMK version: sowohl 1.6.0p29 als auch 2.1.0p16
OS version: RHEL für cmk1.6 und Ubuntu Server 20.04 für cmk2.1
Error message: SNMP Error on : SNMP query timed out after 6 tries within 6.02 seconds
Output of `cmk --debug -vvn hostname`
[cpu_tracking] Start with phase 'busy'
Check_MK version 1.6.0p29
Try aquire lock on /omd/sites/<site>/tmp/check_mk/counters/<hostname>
Got lock on /omd/sites/<site>/tmp/check_mk/counters/<hostname>
Releasing lock on /omd/sites/<site>/tmp/check_mk/counters/<hostname>
Released lock on /omd/sites/<site>/tmp/check_mk/counters/<hostname>
Loading autochecks from /omd/sites/<site>/var/check_mk/autochecks/<hostname>.mk
+ FETCHING DATA
[cpu_tracking] Push phase 'snmp' (Stack: ['busy'])
[snmp] No persisted sections loaded
[snmp] Not using cache (Does not exist)
[snmp] Execute data source
[snmp] Write data to cache file /omd/sites/<site>/tmp/check_mk/data_source_cache/snmp/<hostname>
Try aquire lock on /omd/sites/<site>/tmp/check_mk/data_source_cache/snmp/<hostname>
Got lock on /omd/sites/<site>/tmp/check_mk/data_source_cache/snmp/<hostname>
Releasing lock on /omd/sites/<site>/tmp/check_mk/data_source_cache/snmp/<hostname>
Released lock on /omd/sites/<site>/tmp/check_mk/data_source_cache/snmp/<hostname>
[cpu_tracking] Pop phase 'snmp' (Stack: ['busy', 'snmp'])
[cpu_tracking] Push phase 'agent' (Stack: ['busy'])
[piggyback] No persisted sections loaded
No piggyback files for '<hostname>'. Skip processing.
No piggyback files for '<host-ip>'. Skip processing.
[cpu_tracking] Pop phase 'agent' (Stack: ['busy', 'agent'])
[cpu_tracking] End
OK - [snmp] Success, execution time 0.0 sec | execution_time=0.010 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.003 cmk_time_agent=0.001
Output of `cmk -D --debug -vvn hostname`
<hostname>
Addresses: <host-ip>
Tags: [APPTYPE:NA_APPTYPE], [ORG:ADV], [OS:NA_OS], [USE:Infra], [address_family:ip-v4-only], [agent:no-agent], [criticality:prod], [ip-v4:ip-v4], [malware:unknown], [networking:lan], [piggyback:auto-piggyback], [site:<site>], [snmp:snmp], [snmp-only:snmp-only], [snmp_ds:snmp-v2]
Labels:
Host groups: check_mk
Contact groups: all
Agent mode: No agent
Type of agent:
SNMP (Credentials: 'authPriv, SHA, <snmp-user>, <16-stelliges Passwort>, AES, <16-stelliges Passwort>', Bulk walk: yes, Port: 161, Inline: yes)
Process piggyback data from /omd/sites/<site>/tmp/check_mk/piggyback/<hostname>
Services:
checktype item params description groups
Ich brauche Hilfe für eine Abfrage via SNMPv3 mit Auth & Priv (ohne Agenten).
Ich habe im Wato den Host entsprechend den Einstellungen auf der zu überwachenden Maschine eingerichtet:
Checkmk agent / API integrations… No API integrations, no Checkmk agent
SNMP… SNMP v2 or v3
SNMP credentials… Credentials for SNMPv3 with authentication and privacy (authPriv)Security Level… authentication and encryption
Authentication protocol… SHA-1 (SHA-96)
Security name… <snmp-user>
Authentication password… <16-stelliges Passwort>
Privacy protocol… AES-128
Privacy pass phrase… <16-stelliges Passwort>
Trotzdem schafft es das CheckMK nicht, in den Tests / Diagnostics eine SNMPv3-Verbindung herzustellen, geschweige denn irgendwelche Services zu entdecken.
Rufe ich in der Shell auf dem CheckMK-Host ein snmpget
oder snmpwalk
auf, bekomme ich aber alle angefragten Daten geliefert:
snmpwalk -v3 -u <snmp-user> -a SHA -A <16-stelliges Passwort> -x AES -X <16-stelliges Passwort> -l authPriv <hostname>
Diverse Beiträge in diesem Forum berichten von ähnlich gelagerten Problemen, wenn es um SNMPv3 geht, aber in keinem der Beiträge habe ich eine Lösung für mein Problem finden können.
Deshalb jetzt hier erneut mit der Hoffnung auf Hilfe…
Danke!
