Problems registering the host for communication via TLS
if I would like to register my server in CheckMK in order to communicate via TLS, I get an error message. I am not sure how to handle this. Does anyone have any ideas?
Thank you very much!
CMK version: Checkmk Raw Edition 2.3.0p22
OS version: Ubuntu 22.04.5 LTS"
INFO [cmk_agent_ctl] starting
INFO [cmk_agent_ctl] Loaded config from '"/var/lib/cmk-agent/cmk-agent-ctl.toml"', connection registry from '"/var/lib/cmk-agent/registered_connections.json"'
INFO [cmk_agent_ctl::site_spec] Failed to discover agent receiver port using https.
INFO [cmk_agent_ctl::site_spec] Failed to discover agent receiver port using http.
ERROR [cmk_agent_ctl] Failed to discover agent receiver port from Checkmk REST API, both with http and https. Run with verbose output to see errors.
But:
/var/lib/cmk-agent/cmk-agent-ctl.toml: No such file or directory
On Monitoring Server:
tcp LISTEN 0 2048 *:8000 *:* users:(("gunicorn: worke",pid=1705,fd=7),("gunicorn: maste",pid=1685,fd=7)) uid:999 ino:13513 sk:6 cgroup:/system.slice/check-mk-raw-2.3.0p22.service v6only:0 <->
Could you share the command used for the TLS registration?
Sorry, forgot to post the command:
cmk-agent-ctl -v register --hostname prod002**** --server MONITORING_SERVER_IP --site ***** --user automation
User setting:
I’am using 2FA, btw.
I was now planning to un-register and re-register the agent.
To do this:
But I don’t even see the UUID:
Version: 2.3.0p22
Agent socket: operational
IP allowlist: any
Legacy mode: enabled
No connections```
Any idea here? Unfortunately I didn’t get any further.
Hello, unfortunately nothing works for me. Can anyone here help me? I have tried to re-register the server cleanly.
Do you get again the error message that the agent registration port cannot be found?
If yes you can try to add this port to the registration command.
