CMK version: 2.2.0p32
OS version: Ubuntu 20.04
Error message: Could not read API response, make sure the URL you provided is correct.
I just updated my CheckMK instance to version 2.2.0p32 which is running fine so far.
Besides that I also updated Grafana to the newest version (11.1.3) and tried to use the newest CheckMK plugin (3.3.0) in Grafana. But I can’t connect the plugin to the site. I always get the error Could not read API response, make sure the URL you provided is correct.
The URL looks like this: https://CHECKMK.MYDOMAIN.COM/MYSITE
Also the URL is correct. I already tried it via curl command directly from the Grafana host.
Web developer tools in Edge shows me the following URL is called and the return code is 410:
https://MYGRAFANA:3000/api/datasources/proxy/uid/SOMESORTOFID/cmk/check_mk/webapi.py?action=get_combined_graph_identifications
If I understand this URL correctly it tries to connect to a webapi URL to CheckMK but as far as I know there is no Webapi anymore in this version of CheckMK. Shouldn’t be the Rest API be called?
I also can’t set any version in the plugin like mentioned in the CheckMK guide Integrating Checkmk in Grafana at point 4 picture 3.
