Process monitor for windows ... python.exe running a script
Hi All,
I am trying to monitor for a python script that runs. Windows 10 machine.
In taskmanager, when you view the column “command line” – it is listed exactly as what’s written below with quotes and all. Using the process discovery rules, I can find ‘pythonw.exe’ by itself as just the executable (no commandline matching). But, if I try to monitor with command line regex, no matter what combination I try, it can’t find it. I’ve tried with and without the quotes, while escaping them properly.
Reason I don’t want to monitor for just ‘pythonw.exe’ is to make sure the script is running (pythonw is actually called by python.exe to load this script).
Windows TaskManager “command line” column view:
“C:\Program Files\Python3\pythonw.exe” C:\Users\john\Downloads\test.py
Variations of the regex I’ve tried.
1) pythonw.exe*test.py
2) \"C:\\Program Files\\Python3\\pythonw.exe\" C:\\Users\john\\Downloads\\test.py
3) \"C:\\Program Files\\Python3\\pythonw.exe\"*test.py
First question - what version of agent do you use?
The actual agent and also 1.6 have an option to turn on/off the full command line.
Is this enabled?
ps:
    enabled: yes
    use_wmi: yes
    full_path: yes
This regex will repeat the letter “e” none or once or multiple times. It will surely not match a command line like pythonw.exe test.py. You can use a website like regex101.com to test your patterns. Remember to switch to python mode there.
A correct regex would be .*pythonw\.exe.*test\.py as the ps check always matches from the baginning of the command line.
full_path was not ON, I’ve updated it and used r.sander’s regex, working now, thanks!!!
thanks! i totally didn’t think of trying to use a regex validation tool. i definitely missed a few things as you outlined (probably because it seemingly or luckily worked on another executable I did). with the full_path turned on and your correct regex, it’s working now!
thanks all!
